Because the meter is not release and still being developed, I am unable to do a detailed review. Dave has suggested the we basically run the tests on it and see how it does. The problem with this is I need to do some sort of functional test to know if the meter has changed after testing. So some sort of mini-review is in order if anything just to show that the meter basically works.
I am thinking we would put it through all the same tests I normally keep metrics on. It would give Dave some idea how the meter will stack up against the others I have looked at.
Yes, it could very well get damaged before it gets released. That's the nature of running the tests.
Because that grill starter has damaged so many UNI-Ts, I plan to run it before using the large gun. This assumes it has survived the AC line test.
Just one transient off the grill starter took out the UNI-T UT181A because of a poor layout, where the EEVBLOG rebranded Brymen BM235 has been unstoppable and recently was exposed to a 12KV transient. Where does the 121GW fit?
