A few updates. I began testing the meters today with enough energy to take out the low current fuses. Rather than replace expensive fuses, I am no longer testing the current inputs. However, all of the other modes are still being tested. If you may recall, early on I talked about removing the fuses during the testing. As it turned out, this was not a problem until today.
I am very sorry to say that 2 of the six meters are no longer with us.
![Cry :'(](https://www.eevblog.com/forum/Smileys/default/cry.gif)
The four remaining do not have an easy life ahead of them. If your favorite company was knocked out of the running, it's not because it was treated unfairly. For those who are concerned about meters not functioning during the test, these four surviving brands have shown they produce a more robust product. You may argue that they do not need to but I can tell you, I personally would rather have a meter that does.
On the generator side of things, I have been clear all along that I am not testing to the IEC standards. This is a one off generator just to weed things out. The energy has always been lower than the standard calls for. I am nearing the end of what I can do with this one. It was already at lethal levels but these last four I have a feeling are going to require more than I can put out. But don't worry. I have plans to build a slightly larger and more lethal version..... So stay tuned!
If you want a preview of today's testing, enjoy the following short clip:
