Poll
How many cycles will the KeySight U1281A's detent spring last?
0-2000
7 (16.3%)
2k-4k
5 (11.6%)
4k-8k
16 (37.2%)
8k-16k
8 (18.6%)
>16k (most rubust meter ever made)
7 (16.3%)
Total Members Voted: 40
Author Topic: Handheld meter robustness testing  (Read 1238782 times)
0 Members and 19 Guests are viewing this topic.
Online joeqsmithTopic starter
Re: Handheld meter electrical robustness testing.
« Reply #2575 on: July 04, 2018, 02:03:03 am »
..Also on the plus side, my trusty PACE soldering iron survived.
Maybe Aaron could send out a new one (I mean, just in case..), you've been though a lot! Hope the camera wasn't charging..
I think my Canon SX150 would be worth about a dollar now.
It's not that bad.  The house was not damaged and no one was injured.
Yeah, thank goodness. :phew: Keeping my fingers crossed for your T&M gear that there aren't any more casualties.
I am using a different GPIB controller and have Labview working with it now.   There is a lot more testing to go.   Looks like a few other bits were damaged.  The big one so far if my beloved HP34401A that I bought brand new when they first came out.   That's been a great meter.  It's never given me any trouble in all these years.  I'm not sure I could find parts outside of getting a used one off ebay.   It going to be interesting to see how this plays out with the insurance company.  Take my advice, think about this before you have a problem.
On the plus side, my LeCroy DSOs have all survived.
Offline bitseeker
« Reply #2576 on: July 04, 2018, 02:56:32 am »
I just took a look and Keysight still stocks quite a few parts for the 34401A. You can search their inventory by part number (for something specific) or the model (to see everything that can still be ordered).
Note: Their parts search system is very unfriendly for use on mobile devices.
The following users thanked this post: joeqsmith
« Reply #2577 on: July 04, 2018, 03:38:13 am »
My old HP VNA appears to have survived for the most part.
Went to check the Signal Hound and other USB devices, knowing full well what a poorly designed that bus is.    Sure enough, everything was dead.  After checking the PC port (I had to add a board in the PC to get that Signal Hound stable), the cables, then the hub, it turns out the hub was dead.  I have two of these Anker hubs.  Made a swap and everything fired up.  :phew:
Picture showing my secret to automating many of the tests I have shown.
Offline MacMeter
« Reply #2578 on: July 04, 2018, 04:22:39 am »
Joe, I’m sorry to hear the news. Perhaps the ghosts of tortured meters past, got together for their own revenge.....
Glad everyone is ok.
Offline bitseeker
« Reply #2579 on: July 04, 2018, 04:44:46 am »
 :phew:
Hubs as surge protectors. Noted.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #2580 on: July 04, 2018, 10:17:13 am »
In the early days of USB, nobody cared for transient supression, thus peripherals fell like files. Unless it is a crappy product, nowadays they should have suppressors all around, especially if it is a higher quality product as Anker.
Offline HoracioDos
  • Country: ar
  • Just an IT monkey with a DSO
« Reply #2581 on: July 04, 2018, 12:24:01 pm »
Hello Joe. I'm sorry to hear that. When these things happen you start thinking like a prepper. I'm sure that once you have repaired or replaced your equipment you will be thinking about how to avoid lightning strikes again.
Luckily we only lost a TV set many years ago. Here the insurance companies pay up to a predefined amount of money for electronic equipment according to your contract.
Offline Fungus
« Reply #2582 on: July 04, 2018, 01:08:15 pm »
I think that's universal.
Also: If stuff isn't individually itemized on the policy then you'll get a percentage of the total value of the policy, as determined by them. Usually a pittance.
Offline Fungus
« Reply #2583 on: July 04, 2018, 01:37:57 pm »
We look forward to a new series of videos with joe adding extra MOVs and gas discharge tubes to his house.
(and painting the roof with corona dope)
 :popcorn:
« Reply #2584 on: July 04, 2018, 03:48:21 pm »
I'm not too concerned. Chances of it happening again in my lifetime would be rare.  I may need to adjust my insurance for the lab.
« Reply #2585 on: July 04, 2018, 07:28:00 pm »
Remember the days when you could actually repair your own equipment?   If we really wanted to limit the amount of ewaste, we should mandate companies to produce service manuals and spare parts for anything electronic related....
Pushing ahead with no schematics....
They used 7438s which I did not have on hand.  I did have some 7403s to allow me to troubleshoot the rest of it.  I was out of LS14s and used some LS04s.   No cracks in any of the ICs.
Next...
« Reply #2586 on: July 04, 2018, 08:56:12 pm »
I believe I have identified all of the bad parts required to repair my equipment, including my old HP meter.  Everything is in stock and on order.   There were no signs of an arc any anything.  Even the surge protectors all look fine.  It's very strange.
Now to more pressing problems.  The garage door...  Note the spark gaps in the upper right.   To the left there is an exposed copper trace.  Follow that to the top ground plane the the spark gaps return to.  Note, there is no copper.  You can just see to the right of the plastic mounting bracket where it stopped.  A few other traces are gone as well.
The following users thanked this post: saturation
« Reply #2587 on: July 07, 2018, 05:55:49 pm »
Meter testing has gone off the tracks.
If you have watched my videos, you know I do all of my own repairs and have shown where I have modified a few meters to give people a better idea how they work.   One thing I have mentioned is how important it is to keep things clean.   One of the main solvents I use is isopropyl alcohol but I have also mentioned I use a product called ProClean.   Much of the electronics I work on will have plastic which can be attacked by some cleaners.  I have a friend who tried to clean there laptop once and the case disintegrated over the next few weeks.   :-DD  I pretty much settled on ProClean several years ago.
I use a about a can a year and have been trying another MicroCare product called VERICLEAN.    I've attached a few pictures showing the chemicals they use for the two different products.  I never saw a case where the VERICLEAN damaged plastic.  It does a good job cleaning but if you watch, what I normally do is spray a swab then use that to clean the board.  The VERICLEAN drys faster than the ProClean so I seem to use more off it.   If I have to use a bristle brush to help break things up, the ProClean does a better job.    With the ProClean, if I want it to dry fast, I use the heat gun.  Just a few quick passes and instant dry.
With these latest repairs, I just ran out of the DC1 and decided to go back to the ProClean.    No, I don't work for MicroCare and I am not a distributor for them.  Just thought I would show what I use.
https://electronics.microcare.com/products/clean-flux-remover-vericlean/
https://electronics.microcare.com/products/rma-flux-remover-proclean/
Online IanB
« Reply #2588 on: July 07, 2018, 06:44:19 pm »
I guess I don't much see the point in buying ProClean, unless it is for the convenience of a spray can. It is just a mixture of isopropyl alcohol and ethyl alcohol with HFC 134a as a propellant. You could buy IPA and "green" denatured alcohol and mix up something similar yourself.
(Evidently, the theory is that pure IPA has some limitations as a solvent. Adding some ethanol helps to dissolve those hard to remove deposits. I suspect adding a little distilled water may also be helpful. Experimentation would be needed.)
Offline bitseeker
« Reply #2589 on: July 07, 2018, 07:03:34 pm »
The pressurized delivery is useful in tight areas as well as for general degreasing of small parts (not just flux removal). For open board areas I concur that a bottle of the ingredients and brush/swab is more economical. Right tool for the job, etc.
« Reply #2590 on: July 07, 2018, 07:23:47 pm »
They offer a brush applicator and also the extended trigger like I show.  For the amount I use, I would rather have the sealed can of a known mixture.  But to be clear, I am not suggesting you shouldn't use your WD-40 gasoline break cleaner mixture to work on your $80,000 scope.   :-DD    I'm not getting any sort of kickback and just offering what it is that I have used over the years.   The iso is cheap and again, this is my primary cleaner.  I keep a bottle in the lab and that's all it gets used for.
Online Kean
    • Kean Electronics
« Reply #2591 on: July 08, 2018, 11:16:40 am »
I've not had a good history with pressurised cans of solvent.  For me they regularly seem to end up with no propellant but still plenty of solvent.  Same with cutting fluid for the machine tools.
I switched to 5 litre bulk containers of IPA and now I just buy it in a 20 litre drum (that should last a couple of years!).  I decant from the bulk containers into various dropper and spray bottles around the workshop.  It is so much cheaper in bulk form, and it means you don't hesitate to use a bit more solvent to actually wash away deposits properly.  Also great for filling the ultrasonic cleaner, although I tend to mostly use distilled water and SWAS safewash for that.
I also keep a tin or two of stronger solvents (e.g. Ultrasolve) for those special occasions where you're not worried about damaging plastics.
« Reply #2592 on: July 08, 2018, 12:06:18 pm »
I've not ran into low pressure with the ProClean.  I like that nothing gets into the can.  I use new swabs in the  isopropyl and seal it every time but's it's still open to the environment.
I imagine I go through 470ml of isopropyl every three years or so.  For me, it's not a major expense compared to what I am normally working on.  With swabs, gloves, cleaners, maybe $20/year?
There was an episode of AmpHour where they had a previous employee from Fluke come on the show.  It was one of the times I wished they had just gave him the mike and let him talk.  One of the things he talked about was cleaning the meters.    I've ran into problems with it making videos where I have shown errors in a reading and have to go back in and do a better job.   Not suggesting the free HF meters need that level of cleaning.   :-DD
Short paper on solvents that may be of interest.   It's only about a page long and easy reading.  It talks about the common chemicals used and why/where  they are used.
https://www.smta.org/chapters/files/smta-gdl_getting_pcbs_really_clean.pdf
« Reply #2593 on: July 08, 2018, 03:26:12 pm »
Quick tip with those cans where the propellant gas charge has been used up, but the can is otherwise still fine, and half full of the product, is to take a regular can of lighter gas ( the type you use upside down to fill a gas lighter, typically a 300ml can available for $3 from most places that sell cigarettes and Rizla papers), pull the nozzle off the can, and use one of the supplied red plastic adaptors to refill the can. Works well, you get a new charge of good R600 (propane) in the can to pressurise it, and most cans use propane as a propellant in any case. Have used it on assorted things, including expensive bottles of perfume which had had the propellant evaporate through the rubber seals with time.
Otherwise you have to get a small container, preferably one with a pop off lid, and decant the liquid into it. Pop off lid over screw type, as the liquid will gas off considerably with time, as the dissolved propellant slowly evaporates.
The following users thanked this post: Kean
« Reply #2594 on: July 08, 2018, 07:50:40 pm »
I guess you could stomp on them as well.  At least then you know you are not introducing any possible contamination.
« Reply #2595 on: July 08, 2018, 08:15:06 pm »
Spending 11 hours yesterday in the lab, compressed into 17 minutes...
https://youtu.be/40TaqXOIrHo
Offline bitseeker
« Reply #2596 on: July 09, 2018, 05:19:42 am »
That was quite the sod launcher. :o
« Reply #2597 on: July 17, 2018, 05:49:20 pm »
Was thinking all the side projects are done, everything is repaired.  Time to start working on the next videos.   One is actually a meter.
So, more dead electronics.   I have a device that has several transistors, microcontroller, switches and such.  This device was not plugged in at the time of the strike.  I went to use it and it was totally dead.  I opened it up.  They use a glass fuse.  The glass was shattered.  Transistors were split in two.  Several traces were gone.  Again, it was not plugged in.
Care to guess what this device was?
Offline rsjsouza
  • Eternally curious
« Reply #2598 on: July 17, 2018, 05:51:25 pm »
Harbor Freight DMM?  :-DD
That or an AM/FM radio. I could see something with an antenna being "fried" by EMP.
« Last Edit: July 17, 2018, 05:53:00 pm by rsjsouza »
« Reply #2599 on: July 17, 2018, 08:08:27 pm »
HF meter is a very good guess.  I'll give you another clue, the transient did not come through the power cord, or through the air.  You know it hit a tree....
So, several traces, three transistors, exploded glass fuse and a shorted 104 cap.    After about 2 hours of work, I tried to run it and the microcontroller is hot.  No other activity.  On the plus side, easy to order a new one and get on with the next video...  I've got a date with a cheap meter and want to design the most unimpressive differential probe ever...
