Author Topic: Has this been discussed before? A "decent" portable oscope for $70?  (Read 2128 times)
Offline LightagesTopic starter
  • Canadian po
I just came across this personally, and to me it looks like a good little instrument.
https://www.banggood.com/DSO112A-Upgrade-Version-2MHz-Touch-Screen-TFT-Digital-Mini-Handheld-Oscilloscope-With-Battery-p-977991.html?rmmds=search
and a review:
This looks like a good beginner low budget scope, and a good portable for even some more experienced users. Yes it is limited but it certainly is not a toy from what I can see.
Offline cdev
Re: Has this been discussed before? A "decent" portable oscope for $70?
« Reply #1 on: September 16, 2017, 06:05:19 am »
Both the hardware and the user interface look very nice for $70. Wow.
« Reply #2 on: September 16, 2017, 08:56:37 am »
I could buy a 100MHz analogue scope for that.
Offline Gyro
« Reply #3 on: September 16, 2017, 10:27:29 am »
It's certainly a step up from their DSO138 or DSO Shell - in capability but also in price (significantly).
Of course, with the built in battery it is very portable. The external trigger is an improvement but still not a substitute for 2 channels.
The price issue opens it up to significant competition, both from second hand analogue scopes and from USB scopes. Extreme portability is really its USP.
Best Regards, Chris
Offline Fungus
« Reply #4 on: September 16, 2017, 02:18:59 pm »
The placement of the connectors is a major fail.  :palm:
Nothing should be sticking up in the air from a thing that size. You'll be constantly reaching over that wire to touch the screen. This will stress the connector, etc. You'll have to add a right-angle adapter to the price.
Apart from that... it looks nice.
Obviously it's very limited: Only one channel and I imagine bandwidth will be about 2MHz at best but very useful if that's all you've got.
« Last Edit: September 16, 2017, 02:22:06 pm by Fungus »
Offline cdev
« Reply #5 on: September 16, 2017, 03:12:06 pm »
One could buy a 90 degree adapter so the leads didn't stick out. I've done that with a lot of my devices that use RF connectors. (I've read but have no way to measure the following) ... that sometimes it causes discontinuities in the response in the GHz range but I doubt if that would present many problems here.
Offline joeqsmith
« Reply #6 on: September 16, 2017, 03:16:55 pm »
I saw one of these being used in a video I watched recently.  Does not appear to be very rugged and I would be concerned with snapping off the connectors.  If you need to have a pointer, or recommended anyway, they should have molded a holder for it into the case.
Offline Gyro
« Reply #7 on: September 16, 2017, 03:31:42 pm »
The leads that come with it have 90 degree connectors but they are clip leads rather than a scope probe. My neigbour has one and the force required to remove those tiny connectors is quite high, they're best left connected.
It does raise the question of whether the input will consistently impedance match to a scope probe on all ranges - the DSO138 doesn't (unless it's a x1 of course).
Best Regards, Chris
  • Canadian po
« Reply #8 on: September 16, 2017, 07:33:47 pm »
Yes, but can you carry that analogue scope around in your tool box?
The following users thanked this post: nctnico
« Reply #9 on: September 16, 2017, 09:15:02 pm »
If you carry your toolbox in one hand and the scope in the other it keeps your back straight :)
