Hi There,
I'm trying to decode a simple Manchester signal using Saleae Logic Analyzer
I'm sending 8 bits 11111111 from my microcontroller.
My period is 10 mS and my signal is 1010101010101010.
So the frequency should 100 Hz
The total signal period for al 8 bits is 80 mS
Which should convert to 11111111 in Manchester code.
I've set the bitrate to 100 bits per second.
But the Saleae Logic Manchester decoder doesn't work.
What am i doing wrong?
![](https://i.ibb.co/rtwCKMF/Logic-Manchester.png)
Thanx in advance!
