Author Topic: Hantek USB Oscilloscope  (Read 1245 times)
Offline jbuss_auTopic starter
« on: May 20, 2019, 11:20:02 pm »
Hi all,
I was looking at getting an oscilloscope to practise measurement and use (I am a third year apprentice). I would prefer a nice digital one but they're too expensive.
I saw this one on eBay http://tinyurl.com/hantek-OSC. I will be using it for home use and non critical measurements (accuracy is not necessary)
Has anyone used one or could recommend one for under $200 (I live in Australia so postage for large items is expensive)
Offline vk6zgo
Re: Hantek USB Oscilloscope
« Reply #1 on: May 21, 2019, 04:23:55 am »
Hi all,
Sorry,it seems Safari doesn't speak tinyurl!
There is a very long thread about a particular Hantek USB 'scope (the 6022BE), which, in the main, is far from complimentary!
In my opinion, you would be better off with a secondhand analog Oscilloscope.
Keep a look out for Hamfests in your area, as they often have useful test equipment for sale, including  'scopes.
Some of the earlier "standalone" DSOs which I wouldn't personally touch for my particular usage, are still superior to such things as the 6022BE, but are less common, & unfortunately are usually overpriced.
Offline Gyro
« Reply #2 on: May 21, 2019, 09:06:48 am »
I can't see your TinyURL either, but if it's pointing to a Hantek 6022be then threads of interest are:
https://www.eevblog.com/forum/testgear/hantek-6022be-20mhz-usb-dso/
https://www.eevblog.com/forum/testgear/owon-vds1022i-quick-teardown-(versus-the-hantek-6022be)/
These should hopefully give you enough information to draw your own conclusions.
« Last Edit: May 21, 2019, 07:18:42 pm by Gyro »
Best Regards, Chris
