Hi tinhead !
Do you, or someone else in this forum, can dissipate my doubts ? Many thanks !
[1] I will have soon a DSO5102p
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
, and I will want to enable 450Mhz BW by using the "lst" file method you discovered (I will first enable 200MHz with the hack).
Can I do this via rear or front USB method ? I can see (from the sources of the 200MHz automated hack via (front or rear?) usb port made for Windows) that I can issue the necessary commands to do this job, but I need to know what are the Linux commands necessary to create the "lst" file into the right directory and how to write inside it the necessary data. I don't know Linux
![Undecided :-\](https://www.eevblog.com/forum/Smileys/default/undecided.gif)
so, if someone can tell me the exact command sequence, I can modify the 200MHz hack sources in order to have an all-in-one utility program that can push the bw to 200mhz and also set the filter to 450mhz.
[2] The 200MHz hack can be done with the (front or rear?) USB, without the need to open the DSO and connecting to the UART, right ?
[3] I can see that the DSO5102p doesn't need to be hardware modified in the front-end after the 200MHz hack, and only the "B" version need this, right ?
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
[4] In your first header post, you say :
For all other following benchtop and handheld models with S/N < 15000
- Hantek Handheld DSO1062B/BV, DSO1102B/BV, DSO1202B/BV
- Hantek Handheld DSO1062S, DSO1102S, DSO1152S
- Tekway MSO MST1062B, MST1102B, MST1202B
- Hantek MSO MSO5062D, MSO5102D, MSO5202D
- Voltcraft MSO MSO5062D, MSO5102D, MSO5202D
- Hantek DSO DSO5062BV/BMV, DSO5102BV/BMV, DSO5202BV/BMV
- Extech MS6060, MS6100, MS6200
- Hantek DSO5072P,
DSO5102P, DSO5202P
you have to edit a specific execuatable (as the logo is compiled into it), all necessary tools are here:
https://www.eevblog.com/forum/testgear/hantek-tekway-dso-hack- get-200mhz-bw-for-free/msg200040/#msg200040 For all other following benchtop and handheld models with S/N > 15000
- Hantek DSO5072P,
DSO5102P, DSO5202P
- Hantek MSO5074F, MSO5074FG
- Tekway/Hantek MSO7000B series
- Tekway/Hantek DSO/Handheld/MSO with S/N > 15000 and hw1.0 or hw1.10 (so all with S3C2416 SoC)
All i can tell for now is that the boot logo seems to be compiled into display driver
So, there is an incongruence... what is the true between the two statements about DSO5102P ? This DSO is listed in both the mutually exclusive groups (along with other models too).
Also, I saw on first header post that for the "p" series, the works are "in progress". So, if you will need something from my model, tell me !
![Broken! :-BROKE](https://www.eevblog.com/forum/Smileys/default/smiliey_scope_broke.gif)
Many thanks !
