I'm also interested in the MSO/LA but I checked my DSO and it's a HW1007 board but the PCB header socket (2mm) to connect the LA board is not installed.
Can I solder one myself ? Did I have to add something else to my DSO ?
I will deliver all the necessary small parts. This means also that you will get :
- 1.27mm pin header
- 2 screews
- distance holder
- 5cm flat cable with 20pin IDC plug (to connect DB25 socket to LA/MSO PCB)
- DB25 socket
- DB25 header
You will not get any test cables, but they are really cheap on ebay 251150864536
All you will have to do is to:
- backup firmware (over USB flash drive with backup tool)
- remove sticker (front panel near USB) to expose the hole for DB25 socket. Every hw1007 have such hole.
- solder cable to DB25 socket (the IDT20 cable which will be pluged into LA PCB)
- mount this DB25 socket to front panel. I think there are already holes in the shielding, when you remove the sticker
you will see immediately if there is any drill work necessary.
- solder the 1.27mm pitch header to DSO PCB
- mount the LA PCB to DSO PCB
- connect the IDT20 cable (from DB25) to LA
- reconnect all other DSO cables, so you can boot DSO.
Boot DSO and install new firmware. You will need for this UART<->PC connection and deatiled description how to
do this. I will get special crafted firmware (actually complette dump), this must be complettly restored to DSO
overwriting the old version. The biggest advantage : you will have newer Linux version, which is anyway necessary to
get network working. In Germany i'm offering "instalaltion service", so everybody who don't wish to play with
UART/USB to install firmware or solder cables/header can get this step done by me (for a small fee).
So as long you have :
- screwdriver
- solder station
- UART<->USB adapter cable
- max 2GB USB flash drive
it's not so much to do.
