Hi to all! Thanks Tinhead for your work!
Recently I bought Tekway 1062 model at Pioneer Huang, after a few minutes of work DSO started to hang with the white screen. I found here some people had the same problem with it, and the reason was mentioned has been in 3.3v power supply, which drops down to 3.2v if I remember it right. So this can be fixed very quickly with some metal work, there are 3 regulators on PSU board, or something looks like regulators, I don't know, I don't care. So 2 of these regulators (the ones which are closer to the narrow edges of the PSU board) have not enough radiators, they are very hot, you should enhance these radiators by aluminum profile or change these to a bigger radiators. I used Pi-shaped profile inbetween of original radiator and regulator, I cut about 6cm of profile for each reg, it's better to cut as bigger as the case of DSO can allow, now regulators warm to 40-50 degrees without cooler. This will need because next step will be lowering airflow of the cooler by putting 150ohm resistor in series, the cooler consume too much current that causes this white screen problem. I'm a very poor experienced in electronics, so I can't describe everything, but this trick works for me. If you want to check this trick quickly you can pull off cooler plug and let DSO to work some time without it, there should be no white screens anymore, but the radiators will be hotter than usual, so enhancing of radiators must be did for continuous work.
