As you have made with succes you hack to 200 Mhz, and as i also get problem with doing a back up i put below my first thread expalining the priblem i have.
perhaps you can give me a little help to resobe the backup problem :
Hello, I am new on your forum and send all of you my "hello", my English is not so good as yours so please be patient with my questions.
I received a week ago an Hantek scope DSO5072P with the following information:
Version logs: 3.40.0 (170209.0)
Hardware version: 1010xffff8108
S/N: T1G/035 65xx
As there was a new version of firmware dso5072p20170318. up I decide to make first a backup, like to explained by tinhead without success, by using tool_P_models.zip.
I have tried to rename the file with the same name as the firmware update and I only get the error oXfe message.
When using the original name of the backup file I have the message there are no file for firmware update, after renaming the update file, it seam to work, but after few seconds message "the file has not the right format" is displayed.
Finally,i do the firmware update witch works and only the version log display seam to be changed with a display: 3.40.0(170318.0)
As my knowledge, in Linux is basic can any body body from the forum help me to progress and explain me how to do backup via USB to word converter or perhaps I miss Something in the software backup procedure. Perhaps it is posible to do that via Windows.
I will appreciate your help and sorry again for my English
Many thanks in advance.
