Mark
shit, i have to answer your PM ...
There is newer firmware since day or two available on Hantek website, it does not change that much (if any)
but it is GPL compliant^^
Regards the measurments, sure click Meas button, chose with blue cursor keys the item you wish to change, click F5
to modify and select with F1 the source of measurments.
There are 4 measruments visible in same time, however you can scroll with these blue cursor keys between 4 pages - so you can setup on page 1 and two channel1 and pages 3 and 4 channel 2 - then in principle just scrol up and down between
pages.
Thanks for the reply tinhead.
The problem is, I have done what you said, but it does not change to ch2 when I press F1 (yes, ch2 is on).
Even when channel 1 is off and channel 2 is th eonly one displayed, it won't display amy ch2 measurements or allow ch2 to be selected by pressing F1.
I will upgrade the firmware and see if this is fixed.
(PS, I didn't send you a PM, so it must have been someone else).
Thanks again,
Installed 120423.0 and it has fixed the above issue, thanks. I now have measurements on channel 2.
I updated my previous post with this bug which still remains with 120423.0 firmware for DSO1202B handheld.
To prevent it from being lost on the previous page I'll copy it here again in the hope someone can verify the same on their scope, it would be interesting to know if this "bug" also exists on the desktop models.
When viewing a low freqwave, such as the 1khz probe compensation output, trigger on the rising edge and scroll the waveform to view the falling edge in the middle of the screen (I want to do this to measure jitter in the pulse width). Start with something like 400us/div. Trigger marker shows approx 500us from rising edge trigger to falling edge in middle of screen.
Now change the timebase to 20us/div and note how you have to scroll the waveform again to get the falling edge in the middle of the screen again, and now the time between the trigger and the falling edge is displayed as 350us.
At 8us/div, the time from rising edge trigger to falling edge is displayed as 290us.
At 4us/div, the time from rising edge trigger to falling edge is displayed as 270us.
At 2us/div, the time from rising edge trigger to falling edge is displayed as 260us.
At 800ns/div, the time from rising edge trigger to falling edge is displayed as 255us. etc etc. Should be 500us obviously.
