Author Topic: Hantek - Tekway - DSO hack - get 200MHz bw for free  (Read 2284109 times)
0 Members and 30 Guests are viewing this topic.
Offline tinheadTopic starter
Re: Hantek - Tekway - DSO hack - get 200MHz bw for free
« Reply #2850 on: October 29, 2016, 10:45:47 pm »
Hi, I bought a hantek DSO5062BMV a while back and it looks like there haven't been firmware updates since 2014, I attached my system info window.
I tried installing the latest firmware from the hantek website but i get this error: "No upgrade files detected on USB device". From what I could skim in this thread, the BMV is just a BM with a sd card with video tutorials, the BM model had updates this year. Is there a way to install that firmware on my scope? Did anything really improve since 2012? I am getting increasingly frustrated on how crappy this scope's firmware is :(
send email to Amy Cai caiyijun@hantek.com
in principle they can always compile latest firmware for your hardware version
The following users thanked this post: iromero
Offline iromero
« Reply #2851 on: October 30, 2016, 05:24:03 am »
Thanks a lot! I just sent them an email. If i get updated files I'll upload them here if anyone has a similar model to mine.
Offline iromero
« Reply #2852 on: October 31, 2016, 07:42:55 am »
Got the update from Hantek, they said my kernel is no longer supported for updates (so they just gave me the 2014 one), to the question of how I could update my kernel they said "Buy a new one", lol.
Firmware file i got from Hantek
Offline robots
« Reply #2853 on: November 01, 2016, 10:36:34 am »
tinhead: is it possible to get latest debug firmware from them ? for mso5102d?
« Reply #2854 on: November 01, 2016, 11:31:38 am »
ha ha ha ha-ntek
i have kernel 2.6.30.4 running, with month old firmware 3.30.0 running on my old Tekway (with exact same hw version than yours).
Yes, i do all updates over the network, manually, but it is possible.
Offline iromero
« Reply #2855 on: November 03, 2016, 03:15:52 pm »
ha ha ha ha-ntek
Was there any major improvement that would make it worth the trouble? I can't seem to find release notes for these firmwares.
Offline aandrew
« Reply #2856 on: November 04, 2016, 02:39:58 pm »
Interesting. I'm running 3.2.35 (160630.0) on my MSO5074FG (hw 10020).
A detailed changelog would always be helpful. Doesn't happen often enough :-(
« Reply #2857 on: November 04, 2016, 09:50:32 pm »
for older hardware, there is still hidden direkt link
http://www.hantek.com/Product/DSO5000/DSO5202B_Firmware.zip
where for new hardware, and that link is on Hantek's webpage, is
http://www.hantek.com/Product/DSO5000/DSO5202B_Firmware2.zip
I use the first one, due to the fact that i have old hardware.
Hantek removed the old firmware link, because firmware password is the same, and people with new hardware have very often installed wrong version - which eventually destroyed their DSOs.
Of course one need on older hardware some libs installed, i do have actually dueal boot:  MSO (with very special firmware from Hantek) and DSO (from the first link). For dueal boot i made simple script which checks unused button (probe check) to confirm boot, and F1 / F2 to select between MSO and DSO. Due to the fact that MSO and DSO are using complettly different FPGA designs, i have to boot twice - boot -> select platfrom -> boot again -> confirm, but that not a big deal knowing what necessary (when i reload FPGA design when FPGA is already running, I/O is not working properly).
So yeah, my Tekway (it actually Tekway DSO, with extra MSO PCB and LAN and and and) DSO is bit special, and i have to decrypt/copy files manually when updating, but it works.
For other models, like BMV with old hardware, one can use the firmware from first link, but again maually! SD and 2M point are working on my DSO as well, i did modified mainboard as well (bigger memory).
Offline ElektroQuark
    • ElektroQuark
« Reply #2858 on: November 05, 2016, 04:55:30 pm »
Hi tinhead,
What's latest firmware for this machine?
DSO5202B
sw 2.06.3 (130814.0)
hw 10070x555583eb
Thank you very much!
Offline Bondguy
« Reply #2859 on: November 05, 2016, 07:29:33 pm »
Tinhead,
Can you please also
for this version please recommend an upgrade solution?
DSO5102BM
sw 2.06.3 (120423.0)
hw 10070x555583e9
I read that that kind of scope had probably also bad CPLD design installed.
Can you please also  let me know  how to upgrade that CPLD? I already have
Mini Altera FPGA CPLD USB Blaster programmer
Thanks a lot
Offline christensen
« Reply #2860 on: November 29, 2016, 07:41:58 am »
Hi Guys,
My components arrived for LAN modification. Before i start to solder it i want to ask for what is the battery on the main board?
I just want to remove it before modification, does will lose some calibration information?
Offline blackriver
« Reply #2861 on: November 29, 2016, 01:16:03 pm »
Hi Guys ;)
I'v bought bricked Voltcraft DSO-1062D, I look for full zImage (It will be grateful).
Voltcraft DSO1062D
sw ???
hw 1.01
There are linux 3.2.35 and damaged rootfs partition.
« Last Edit: December 01, 2016, 01:05:18 pm by blackriver »
Offline anfang
« Reply #2862 on: November 29, 2016, 04:50:55 pm »
Hi tinhead,
are the links correct? Ist the first "for old hw" valid for e.g. Voltcraft DSO-3062C?
the content of both is file starting dso5kb_ ... only different datecode.
There is some fw dst1kb_2.06.3_15202b_fact(140211.0).up on russian site, do you have some info about it?
best regards
Offline Front_Line
  • Country: ru
« Reply #2863 on: December 05, 2016, 07:13:37 am »
Hello.
dso5102p hacked 200MHz.
Here is a picture After starting on dso5102p without probe:
When measuring other oscilloscope on line +12A at point TP907 is such a picture:
Measurements at some points:
TP302
TP403
Once connected to the probe dso5102p to channel 2, and measured them tp907 point everything was fine.
The pdf file put down signals at the control points measured by other oscilloscope after launch without probes and signals when the measuring point is tp907 dso5102p themselves.
All other control points on the voltage (901,904,905) such as blade 907 no.
Tell me what could be the problem?
I found the cause. It was defective 12V regulator 78m12, replaced the 7812A solve the problem.!!
« Last Edit: December 27, 2016, 08:19:56 am by Front_Line »
Offline vferencz
« Reply #2864 on: December 08, 2016, 05:53:02 pm »
Hi Guys,
Please help me to backup data of my DSO.
model: DSO5202BM
sw version: 3.30.0 (130709.0)
hw version 1010x5555830f
serial number T1G/012 01xxxxx
I want to back up the DSO before adding the parts for LAN. No success.  |O
I tried:
-   DSO-USB-Tool, http://peter.dreisiebner.at/dso-usb-tool/  with inserted  flash drive in USB port and running these command from the shell:
nanddump -o -b -f /mnt/udisk/dump/boot.bin /dev/mtd0
nanddump -o -b -f /mnt/udisk/dump/logo.bin /dev/mtd1
nanddump -o -b -f /mnt/udisk/dump/kernel.bin /dev/mtd2
nanddump -o -b -f /mnt/udisk/dump/root.bin /dev/mtd3
-   physically connected (via UART<->USB converter) and PuTTY (log attached).
« Last Edit: December 08, 2016, 06:00:55 pm by vferencz »
Offline mikga32
« Reply #2865 on: December 08, 2016, 11:15:38 pm »
What's bricked MSO5102D worth? in Canada
It boots to a blue screen then dark, cycles ..
Serial: T1209464
made in 2011 hw 1007
I clicked on wrong firmware MSO5202D instead of MSO5102D
And installed wrong firmware..
Offline jimiz
« Reply #2866 on: December 20, 2016, 08:50:37 pm »
 ;)HI
I have VOLTCRAFT DSO-1062D   60Mhz
the info about are:
SW : 2.06.3 (121023.0)
HW : 10070x555583eb
ser  : T1*/01200****   (so down 15000)
bout count : 51
upgrade count : 0
lcd.fornt.TS : 0
usb/pc see DSO without problem.
I'v use the DSO-BW-Changer , and update to 200 Mhz
now i can set to 2.00 nv  (before was 4)
I see on DSO-USB-Tool , with shell command ls  , found a DSO 1202b.
I like ask please IF Is better I update a firmware better (what exactly) ?
and if the "hardware" work fine to 200 Mhz or need something update.
THANKS!!  :-+
« Last Edit: December 21, 2016, 04:03:55 pm by jimiz »
Offline mikga32
« Reply #2867 on: December 26, 2016, 09:30:33 am »
All I know is if it's working don't upgrade firmware, I did and unit is totally bricked but Hantek did try to help send me
a terminal program and all my MSO5102D does is send machine code no text, so I send them the crap it output and
some scope volts timing screens. That was a few weeks ago..
Some how either a virus or bad usb drive made it unworkable.
Normally the firmware would (should) check if the unit is correct for upgrade.. ( got MSO5202D) clicked wrong link!
That didn't happen. That's how I ended up here ~1 year ago.
The unit has very low hours on it! have the 3.3v, ground, Tx, Rx, (4 wires) cabled out the back.
Hooked up to a PicAxe 027 (FTDI chip inside) USB cable, it's ~3.6 volts. with 3 wires only.
Problem is I don't know about the UART or TTL stuff very well at all. Other than TTL is Transistor To Transistor Logic?
The Chip inside the unit is complex!
Offline jcrubin
    • Technocoma
« Reply #2868 on: December 26, 2016, 02:04:29 pm »
I finally got around to upgrading my 5000P series and documented it by making a Movie, everything went just fine.
CVM CATAPVLTAE PROSCRIPTAE ERVNT TVM SOLI PROSCRIPTI CATAPVLTAS HABEBVNT
https://www.youtube.com/c/jordanrubin6502
The following users thanked this post: Macbeth
Offline minescumarius
« Reply #2869 on: January 03, 2017, 06:32:02 am »
Hello,
I have an Hantek DSO5102P oscilloscope with stock firmware dso5kp_func_dso5102p20140208 on it, that has not been used for the last 6 months.
Yesterday I tried to turn it on and remains frozen on screen logo. I connected a serial interface to internal port and I got the following result (text file).
How can I solve this problem? I did dump restore before installing the firmware. If I try to rewrite root.bin with DNW freezes, as shown in picture.
I can access the boot menu but I can not get into console. Please help.
Offline app-note
« Reply #2870 on: January 09, 2017, 08:50:45 pm »
I have 2x scopes of the of revision hw1005, hacked to 200MHz bandwidth and updated to firmware 130814.
Both worked fine, until a year ago, when the first one started to hang at step 8/36 of self calibration - error code 0x400.
Now the second Hantek fails self calibration too, only at step 2/36 with error code 0xa00
Any idea, how to fix it ? Is it caused by a HW defect and what components are most likely concerned ?
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
« Reply #2871 on: January 11, 2017, 10:28:15 am »
I also had issues with failing calibration when I developed my improved 250MHz analog hack (www.eevblog.com/forum/testgear/hantek-tekway-dso-hack-get-200mhz-bw-for-free/msg979548/#msg979548). It seems that the they check if offset and gain of the input stage are within reasonable ranges. I would look there first.
We Are The Watt - Resistance Is Futile!
Offline tatus1969
    • keenlab
« Reply #2872 on: January 11, 2017, 10:39:26 am »
it seems that I never had posted an update of my analog hack here that I made. Here it is, for anyone interested ;)
Offline Front_Line
  • Country: ru
« Reply #2873 on: January 14, 2017, 12:14:20 pm »
Is it possible to view a log of calibration?
« Reply #2874 on: January 20, 2017, 08:20:00 am »
Hello,
Problem solved via JTAG port. The programming interface is simple. Cost insignificant. Programming requires 270 minutes with this interface.
Very slow speed, only 10K per second with this LPT interface. But you can correct firmware problems. My problem consisted in bad NandFlash.
I changed NandFlash. I programmed NandFlash with fw_beackup.bin
1. Install H-Jtag software ( download from http://www.hjtag.com/en/index.asp )
2. Set the parallel port (JTAG Interface pins)
3. Open the file "config processor HJTAG.hfc" in H-Flasher with Load
4. Write fw_beackup.bin in NandFlash
5. Restart the power
The following users thanked this post: mikga32, dec123ua, Taviman, gold oxide
