thanks Robert for the pics!
The not assembled SSOP28 IC between NAND and 74HC4053 (USB mux) is UDA1341TS (connected via IIS).
The SOP8 is an amp for headphones, P1/P2 connectors nears that IC are routed to these phones/mis connectors too (near USB client).
No idea for what a DSO need audio codec, but who cares, this is in principle Linux box with "DSO functionality" so what.
Same for SD card (ok, it can be used as additional memory/boot device), on the old hw revision the SDIO port is
not routed.
So in principle Hantek was nice enough to route all these unused pins to what-they-designed-for.
Probably they will never use sound on DSO, but we can. SD card is nice for hacks too.
Other changes/not assembled parts:
- some status LEDs, but that's not new
- new 60pin 1.27 pitch I/O header - very nice, much more addons possible than with the old one.
- on bottom side for different DAC IC (instead of LTC2601 on the top side)
- diag connectors
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
within input stage, hmm (lol, input stage open-detector?)
- U12 on bottom, J4 on top and all these parts around J4 (abouve J700 on top) - hmm (i saw that parts
combination somewhere near FPGA, think ...)
- opamp TLV272 replaced by TLV274, no function change, just some savings
- USB mux with 4053 (S3C2440 is having host/client or 2 x host USB ports, the "mux" is probably detecting VUSB
voltage on USB client and swithing off the second USB host on the front side)
- on bottom side really ugly soldered single gate 74hc04 with some resistors as jumpers, let me gues - for EEPROM WP ?
- polyfuse for both front USB ports (good idea)
- "RJ45 jack" routed probably to the long I/O header, so LAN addonboard will be plugged there.
- on the bottom side 6 x 0ohm "jumpers" block connected to FPGA, hmm (model detection?)
- on the bottom side some not assembled resistors/transistor, routed to S3C2440, no idea what for.
- input channels JFET changed to
(i can't read the device marking)
Many changes, especially these "jumpers" are interessting for future hacking.
