Hi, first post here. sorry about the long post.
I can tell you that the eeprom hacking method posted by
villamany is not for the faint hearted, there is a real risk of bricking your oscilloscope, so if you follow the website instructions (
http://tefatronix.g6.cz/display.php?page=hantek&lang=en) do it carefully. I have spent hours fixing a recovery loop, and after sucessfully modding the eeprom it still wasn't the right way, so it couldn't perform self calibration without success, it gave error 0x802.
Here is how i managed to do it.
Get acess to the console via rs232 adapter connected to the pcb, the pads near the usb connector
use Putty, or similar and get the i2c.log file copied to the usb stick. insert usb stick on your computer.
I use windows so i edited the file with HxD hex editor.
On top of the HxD editor you will see a window that reads "Windows(ANSI)", select in the dropdown list "DOS/IBM-ASCII(OEM)" so you can see the unix line terminators "◙" on each line.
Delete all 0x00 entries until the "[" character in "[--LOG0--], there is usually a bunch of 0x00 in the middle of the file, erase them too, and also at the end of the file, after "[bw]200◙".
So your file should look like this on HxD (the serial number is censored
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
![Hantek - Tekway - DSO hack - get 200MHz bw for free](https://www.eevblog.com/forum/index.php?action=dlattach;topic=1571.0;attach=967328;image)
save it as i2c.org and connect stick to the dso.
Continue with the site instructions and reboot the dso when you're finished.
Now comes the important part. if the first message after rebooting the dso is not "formatting e2prom" but "backing e2prom", or self calibration fails then your file is not edited right(see image above), take special precaution with extra spaces or missing characters, it must be
exactly like the image above, no more, no less.
If it is stuck in a recovery loop, connect via terminal(rs232 to usb adaptor) and choose on the dso the recovery option and wait, when "backing i2prom" or "formatting i2prom" appear on the dso screen hit killalll dsod, two times to be sure...
and copy i2c.org on the usb stick to both i2c.org and i2c.log:
cp /mnt/udisk i2c.org i2c.org
cp /mnt/udisk i2c.org i2c.log
touch i2c.format
sync
reboot
See if the dso reboots and "format e2prom" appears normally and after that it reboots normally, if so perform the self calibration, it should pass with success, if not, take your time evaluate your modded i2c.log file with patience, like the site said, a single misplaced character can brick or make your dso fail self calibration.
Simply don't rush it, take time and do it carefully.
