Author Topic: Hantek - Tekway - DSO hack - get 200MHz bw for free  (Read 2283633 times)
Offline tinheadTopic starter
Re: Hantek - Tekway - DSO hack - get 200MHz bw for free
« Reply #2200 on: February 02, 2014, 12:19:40 am »
Dear tinhead, could you throw me a NAND dump from DSO5102B. I'll try to pour through the programmer. May start! ARM S3C2416 Processor
well, when i got one i will share with you .. as you can see here:
https://www.eevblog.com/forum/testgear/hantek-tekway-dso-hack-get-200mhz-bw-for-free/msg377178/#msg377178
i'm looking for full dump of the new models as well ...
Offline rudy1589
« Reply #2201 on: February 02, 2014, 12:30:24 am »
EDIT: in case oyu really have 2.06.3, here download link. There are two fw version, one from April 2013 and one from September. Try first the one from April, then if this was working the one from September. Both are original files, for DSO5102B, so they must work.
Thank you VERY much!
 It now shows 2.06.3(130814.0) The September one worked!
« Reply #2202 on: February 02, 2014, 01:18:00 am »
ok, then try to update to the patched version (the one above which gives you 0x7F error). But rename the update file to
dst1kb_2.06.3_15102b_fact(130814.1).up first ^^
Offline rudy1589
« Reply #2203 on: February 02, 2014, 02:31:24 am »
Wow! You're good! Thanks for your help! https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif
Offline gafbich
« Reply #2204 on: February 02, 2014, 07:22:19 pm »
Please put dump NAND DSO5202b. ?an help dump!
Offline kallsop
« Reply #2205 on: February 04, 2014, 12:15:57 am »
Got my Hantek DSO5062B today. Firmware 2.06.3 (130306.0). Hardware version 10070x555583eb. Was able to make a firmware backup to USB memory stick, then install PC Zadig USB driver, then run DSO-USB-Tool and move the dst1062b directory to dst1202b. Reboot twice. Now have a 200MHz scope. I don't have a high frequency square wave to check the analog input bandwidth, maybe later. Thanks again. If there is any information you want from this 'scope, let me know.
« Reply #2206 on: February 04, 2014, 12:46:10 am »
no, have all i need from hw1007
Thanks again
you welcome :)
Offline kallsop
« Reply #2207 on: February 05, 2014, 04:17:39 am »
I also did the 2 file edits to make the boot logo DSO5202B.
On the Hantek web site, there are firmware files e.g. dso5kb_func_dso5062b20140111, which I expect are newer than what is in my DSO considering they are dated January 11th 2014.
Tried to update using the DSO5062B files and no go, got a 0xfe error. Also tried the DSO5202B update file, same 0xfe error. I did read about a 0xfe error for older hardware, that doesn't seem to be the explanation here. Anyone loaded the newer firmware on a DSO5062B  patched to DSO5202B?
« Reply #2208 on: February 05, 2014, 06:17:32 am »
and that firmware on the website is ONLY for models with newer hardware, this is why you getting update error. For your DSO, the latest is the one published here in thread.
Offline dlrpgmsvc
« Reply #2209 on: February 05, 2014, 02:55:16 pm »
I saw on first header post that for the "p" series, the works are "in progress". So, if you will need something from this model, tell me !  :-BROKE
Offline kallsop
« Reply #2210 on: February 05, 2014, 05:14:54 pm »
OK, it would be nice if Hantek web site would say that too!
Upgraded to dst1kb_2.06.3__130814.1_.up, looks good.
Offline rudy1589
« Reply #2211 on: February 08, 2014, 06:19:51 pm »
Does this imply that Hantek isn't going to supply firmware update for older hardware?
« Last Edit: February 08, 2014, 06:22:02 pm by rudy1589 »
Offline rudy1589
« Reply #2212 on: February 08, 2014, 06:23:51 pm »
Offline dlrpgmsvc
« Reply #2213 on: February 09, 2014, 12:04:52 am »
I know that probes are not all good for all scopes due to different input circuitries. What 500MHz 10x active probe are you using on Hantek DSO ? For DSO5102P what is best ? I found on Ebay some active probes but they all have a multi-pin connector (to the scope side) in addition to the usual bajonet one, like this one: http://www.ebay.it/itm/Tektronix-P6245-1-5-GHz-15-Volt-1-3-m-Length-Active-Probe-/221284277814?pt=LH_DefaultDomain_0&hash=item3385921e36 so I think this is not good for DSO5102P, right ? Excuse my noob questions...
« Last Edit: February 09, 2014, 01:05:00 pm by dlrpgmsvc »
Offline kallsop
« Reply #2214 on: February 11, 2014, 12:02:50 pm »
FYI: not too impressed with the software quality. In the space of one day, I have had the DSO5062B freeze and then do a BSOD and reboot, the TTScope app running Virtual Panel never runs for 24 hours without a crash, and when I turned off power to the DSO while it was connected to PC by USB, it caused the PC to BSOD. The PC did its memory dump and then it sits there, have to manually reset the PC. Sometimes I use VNC to connect to this PC from a remote location. I have no way to reboot the BSOD'd PC remotely, so this is really bad news. Not that it should matter, but the PC is running Windows 7 64 bit with all updates and everything else on the PC is rock solid, it's on 24/7 and never crashes. If I can see a pattern I'll submit bug reports, but so far the Hantek crashes in firmware/USB/TTScope look random.
Offline rosasharn
« Reply #2215 on: February 12, 2014, 06:36:28 am »
I would like to know how to obtain the VGA Option for MSO5202D?
Offline limpid
« Reply #2216 on: February 15, 2014, 07:30:34 am »
VGA has a board, do you have this board for MSO5202D?
Offline rosasharn
« Reply #2217 on: February 15, 2014, 08:25:48 am »
No, I haven't. Where I could get it?
Offline gafbich
« Reply #2218 on: February 17, 2014, 02:27:59 pm »
Offline rosasharn
« Reply #2219 on: February 18, 2014, 06:57:31 am »
Where to buy the VGA board for MSO5202D, the internet providers don't offer it.
Offline khach
« Reply #2220 on: February 18, 2014, 12:42:26 pm »
Anyone tried to recompile or migrate from open source Welec W2000A http://sourceforge.net/apps/trac/welecw2000a/browser to Tekway? Welec repo contain two different scope application and FPGA design with embedded CPU soft core. Is this good starting point for open-source DSO project?
Offline kallsop
« Reply #2221 on: February 18, 2014, 03:10:11 pm »
From what I have read, the Welec scope firmware was terrible in design and execution, it went open source after the company went bankrupt, and the community tried to fix the many bugs. It probably has no value.
Offline Macbeth
« Reply #2222 on: February 19, 2014, 06:49:03 pm »
Tinhead, I understand you only have HW dumps up to V1007.
I have a Hantek MSO5102D that is HW 1010x55558340 - does that mean V1010?
SW is version 3.2.35 (131029.0)
Serial is T 1G/012 016xxx
Let me know what to do if you need anything from this scope. I certainly would like to unlock 200MHz, but all in good time!
I would also like to get my Siglent SDG1025 upgraded to SDG1050 (it's just 25MHz sine to 50MHz sine) - but that's a seperate hack.
Offline bjorn
« Reply #2223 on: February 22, 2014, 01:08:48 pm »
Hi all,
Are The LA pcb addon boards still available? I'm still searching in the thread but I can't find the info.
grtz
Offline rudy1589
« Reply #2224 on: February 23, 2014, 05:57:55 pm »
What ever happened to TinHead?
  I used to enjoy all the information that he would post here.
