Author Topic: Hantek HDG2002B AWG: 5Mhz or 100MHz? Let's see!  (Read 243474 times)
Offline rodlaird
Re: Hantek HDG2002B AWG: 5Mhz or 100MHz? Let's see!
« Reply #525 on: August 15, 2015, 07:21:33 am »
I suppose that the script can't find system.inf... What firmware version do you have?
This script should work on a HDB2002B with firmware >= 1.00.2 where system.inf is located in /dso/root. It won't work with firmware 1.00.1 where system.inf is in /etc.
Indeed I am FW 1.00.1. Which means of course that the other firmware update scripts will also not work.
I would be most grateful for a set of files that allowed me to move up to something better than my current level! If you could mod your files and provide a link that would be superb. :-+
Rod
« Last Edit: August 15, 2015, 07:46:07 am by rodlaird »
Offline robert_
« Reply #526 on: August 18, 2015, 10:44:03 pm »
Some news on the PSU/isolation thing:
I did try installing the digital isolators. ADUM2400 fits pinout-wise and data-direction-wise too (tested for U14 only at the moment).
However, i got sent the wrong parts (-ARW suffix) from an incompetent seller, which are only rated for 1Mbd and have much too high delay, so it doesnt work. Some signal gets trough, but it doesnt look good.
Now ordering the correct (90Mbd) -CRW again, but this time at a distributor that hopefully knows what they are doing...
Offline rodlaird
« Reply #527 on: August 19, 2015, 02:04:03 am »
Not sure what you all will make of this. I have been in touch with Hantek because of a dodgy PSU in my HDG2002B. They are going to ship me a new one. But I also mentioned that a firmware update would be nice.
They provided me this file... https://dl.dropboxusercontent.com/u/46144181/afg_hdg2000b_150807.upk  :-+
    ...which then bricked my machine. Sigh.  |O
Maybe someone in the forum can make something of it. It is dated very recently...
So now seeing if Hantek can sort this out. (Yes I know I can get in there with a UART as I have before, but for now I want to see how the "official" solution works out before I have to go up a learning curve I'd rather avoid)
cheers
Rod
Offline rodlaird
« Reply #528 on: August 22, 2015, 04:22:21 am »
Well, Hantek actually responded with a set of files that seem to provide a telnet link via the USB port. https://dl.dropboxusercontent.com/u/46144181/Hantek%20USB%20cmd.zip This certainly got my device working again. I suspect this might be a more generally useful tool if you want to shortcut the UART access effort. I leave it to those with the skills and interest in the forum to investigate...
cheers
Rod
Offline dafields
« Reply #529 on: August 22, 2015, 08:21:15 am »
I got my new HDG2002B with the following
PCB 1004.1
SW 1.00.3.03.05 (150710.0)
FPGA 41
Can still be hacked to HDG2102C.
fremen67, I found a bug in your spreadsheet when attempting to do the calibration with my Rigol DS2000 scope. In the function "GetVoltFromDS2000A" you have "GetTimeScale " when it should be "GetDS2000ATimeScale". Once I changed that (and spoofed the DS2000 into DS2000A) it then worked.
great work everyone on enabling this easy upgrade.
Offline fremen67Topic starter
« Reply #530 on: August 24, 2015, 11:34:38 pm »
Rod
FW 1.00.1 systems do not have the recovery partition which I use to provide upgrades to new firmwares (this started with FW 1.00.2). Upgrading from FW 1.00.1 needs a complete erase of the nandflash and requires a new u-boot. This should be possible wthout opening the HDG with a SD card and some modifications on u-boot but in case of a problem, you would end up with a bricked unit...
Regarding scripts like the one which changes the HDG model, this would not be a big deal to have a generic one. If you need it, I could do it.
I'm a machine! And I can know much more! I can experience so much more. But I'm trapped in this absurd body!
« Reply #531 on: August 24, 2015, 11:36:25 pm »
Too bad. Lest's hope you will be luckier with the next order  :)
« Reply #532 on: August 24, 2015, 11:38:30 pm »
cheers
Rod
Interresting. I will have a look at it.
« Reply #533 on: August 24, 2015, 11:40:20 pm »
cheers
Rod
Did it restore the version you had before on your HDG?
« Reply #534 on: August 24, 2015, 11:49:12 pm »
PCB 1004.1
FPGA 41
That's a very good news  :-+ . Would you be able to dump your device and post the files somewhere? I will create an upgrade package for this new version and upload it on my oneDrive.
Thank you for the feedback. I will update the Excel file. As I don't have a DS2000, I was unable to test it  ;)
Offline dafields
« Reply #535 on: August 25, 2015, 06:24:57 am »
I used your backup and upgrade tools to hack my unit. Link below for the set of backup files I made.
https://www.dropbox.com/s/ta70rpdwly10hcn/HDG2002B_backup.zip?dl=0
Offline idpromnut
« Reply #536 on: August 25, 2015, 02:51:30 pm »
cheers
Rod
I upgraded my early unit with this firmware and it looks like it fixes a few annoying bugs!  I will need to re-do a batch of tests;  shall do that soon and post my findings.
Offline rodlaird
« Reply #537 on: August 29, 2015, 10:40:47 pm »
cheers
Rod
It did restore with the new firmware upgrade in place 1.00.4 I think
Offline idpromnut
« Reply #538 on: August 30, 2015, 03:02:19 am »
Of course, now I just found a "blue screen of death" crash bug when trying to use the Arb function.   :-//
« Reply #539 on: September 01, 2015, 12:36:55 am »
Of course. So did I...
There are more preloaded arb functions and they are grouped by themes: Math (6), Project (15), DistrFun (4), TrigFun (5), WindFun ( 8 ) and Biology (4). Each function seems to be defined with 3 different sample counts. The files are in /dso/etc/data:
abs_sine_16384_Samples.haf
abs_sine_250_Samples.haf
abs_sine_4096_Samples.haf
acos_16384_Samples.haf
acos_250_Samples.haf
acos_4096_Samples.haf
asin_16384_Samples.haf
asin_250_Samples.haf
asin_4096_Samples.haf
atan_16384_Samples.haf
atan_250_Samples.haf
atan_4096_Samples.haf
barlett_16384_Samples.haf
barlett_250_Samples.haf
barlett_4096_Samples.haf
bessel_16384_Samples.haf
bessel_250_Samples.haf
bessel_4096_Samples.haf
blackman_16384_Samples.haf
blackman_250_Samples.haf
blackman_4096_Samples.haf
cardiac_16384_Samples.haf
cardiac_250_Samples.haf
cardiac_4096_Samples.haf
cauchy_16384_Samples.haf
cauchy_250_Samples.haf
cauchy_4096_Samples.haf
cubic_16384_Samples.haf
cubic_250_Samples.haf
cubic_4096_Samples.haf
damped_osc_16384_Samples.haf
damped_osc_250_Samples.haf
damped_osc_4096_Samples.haf
dirichlet_16384_Samples.haf
dirichlet_250_Samples.haf
dirichlet_4096_Samples.haf
discharge_16384_Samples.haf
discharge_250_Samples.haf
discharge_4096_Samples.haf
eeg_16384_Samples.haf
eeg_250_Samples.haf
eeg_4096_Samples.haf
emg_16384_Samples.haf
emg_250_Samples.haf
emg_4096_Samples.haf
eog_16384_Samples.haf
eog_250_Samples.haf
eog_4096_Samples.haf
exp_rise_16384_Samples.haf
exp_rise_250_Samples.haf
exp_rise_4096_Samples.haf
gamma_16384_Samples.haf
gamma_250_Samples.haf
gamma_4096_Samples.haf
hamming_16384_Samples.haf
hamming_250_Samples.haf
hamming_4096_Samples.haf
hanning_16384_Samples.haf
hanning_250_Samples.haf
hanning_4096_Samples.haf
kaiser_16384_Samples.haf
kaiser_250_Samples.haf
kaiser_4096_Samples.haf
laplace_16384_Samples.haf
laplace_250_Samples.haf
laplace_4096_Samples.haf
log_16384_Samples.haf
log_250_Samples.haf
log_4096_Samples.haf
mc_noise_16384_Samples.haf
mc_noise_250_Samples.haf
mc_noise_4096_Samples.haf
nuttall_16384_Samples.haf
nuttall_250_Samples.haf
nuttall_4096_Samples.haf
quake_16384_Samples.haf
quake_250_Samples.haf
quake_4096_Samples.haf
radar_16384_Samples.haf
radar_250_Samples.haf
radar_4096_Samples.haf
ripple_16384_Samples.haf
ripple_250_Samples.haf
ripple_4096_Samples.haf
sqrt_16384_Samples.haf
sqrt_250_Samples.haf
sqrt_4096_Samples.haf
stair_dn_16384_Samples.haf
stair_dn_250_Samples.haf
stair_dn_4096_Samples.haf
stair_up_16384_Samples.haf
stair_up_250_Samples.haf
stair_up_4096_Samples.haf
swing_osc_16384_Samples.haf
swing_osc_250_Samples.haf
swing_osc_4096_Samples.haf
tan_250_Samples.haf
trapezia_16384_Samples.haf
trapezia_250_Samples.haf
trapezia_4096_Samples.haf
triang_16384_Samples.haf
triang_250_Samples.haf
triang_4096_Samples.haf
tukey_16384_Samples.haf
tukey_250_Samples.haf
tukey_4096_Samples.haf
tv_16384_Samples.haf
tv_250_Samples.haf
tv_4096_Samples.haf
There is also a new function in each menu which allows to duplicate the current waveform on the other channel (CH1=CH2), and a blue arrow has been added on soft keys which call a sub-menu.
The trigger button does not seem to call a trigger menu anymore ...
« Last Edit: September 01, 2015, 12:41:06 am by fremen67 »
Offline smgvbest
    • Kilbourne Astronomics
« Reply #540 on: September 01, 2015, 11:20:02 am »
Anyone know if this fixed the self test failure on the zoom unit I and a few others see on newer units?
Sandra
(Yes, I am a Woman :p )
Offline wojt
« Reply #541 on: September 11, 2015, 11:59:45 pm »
New HDG user has come  :)
I bought mine a few days ago and "upgraded" bandwidth today (even without violating warranty sticker:)). Thanks to the people who made it possible.
As I don't have genuine Excel here, I wrote my my own calibration tool in Python. Wouldn't mind to share if anyone wants.
Strange, my unit does not perform self test. When I click it, HDG makes some relay clicks without displaying anything and reboots after a few seconds.
PCB: 1004.1
FW: 1.0.3.2.3 (150420)
FPGA: 30
KBD: 3
I saw people reporting higher FPGAs. Is anyone aware of diferences?
« Last Edit: September 12, 2015, 01:12:16 am by wojt »
« Reply #542 on: September 12, 2015, 10:29:37 pm »
PCB: 1004.1
FPGA: 30
KBD: 3
Welcome wojt  :)
There is a newer firmware version available. This would update your FPGA to v40.
I suggest that you update your device to the latest version. This may solve your problem ...
It is available on my onedrive here: https://onedrive.live.com/redir?resid=C666E0DC0AF0C9E2!139&authkey=!AFktskq2NZNoiws&ithint=folder%2cupk
@sandra: I suggest that you also upgrade your device to this last version.
Offline smgvbest
« Reply #543 on: September 13, 2015, 03:48:31 am »
Hey  fremen67
Thank you, I will do that.
Sandra
Offline wojt
« Reply #544 on: September 13, 2015, 11:27:00 pm »
thanks fremen, waveforms look cleaner now and self test is passed :)
Offline smgvbest
« Reply #545 on: September 13, 2015, 11:57:19 pm »
fremen67
Did the update and the zoom errors on the self test are gone.
Sandra
Offline backfromearth
« Reply #546 on: September 14, 2015, 01:20:12 pm »
Hello, could someone summarize the pending problems , unresolved by the last update available, because I think it's time for me to decide to buy it or not : the 2002b is available at 230 EUR on aliexpress now !!
Thanks
Offline idpromnut
« Reply #547 on: September 14, 2015, 05:02:39 pm »
I also noticed last night that this FW update seems to have broken both LF and HF frequency counters.  Booo.
Offline nbritton
« Reply #548 on: September 19, 2015, 08:48:23 am »
Can someone post some screenshots of square waves on a unit that is fully calibrated? I'm wondering if calibration helped correct the deficiencies in the waveform.
Offline nbritton
« Reply #549 on: September 19, 2015, 09:18:26 am »
What model versions of the device don't have the HF counter and LAN port? What models has all the equitment?
Furthermore, what is the difference between the 2000B and the 2000C?
HDG2002B 5 MHz
HDG2012B 10 MHz
HDG2022B 20 MHz
HDG2032B 30 MHz
HDG2062B 60 MHz
??????HDG2082B 80 MHz
HDG2102B 100 MHz
HDG2032C 30 MHz
HDG2052C 50 MHz
HDG2072C 70 MHz
HDG2102C 100 MHz
