The unit is reporting software version 1.0.1.1, kernel 3.2.35, FPGA 10, PCB ? ? ?.
That is strange. It seems you have a new software version and an old FPGA version...
The last software version was 1.00.2(140422.0) with FPGA version 12 reported by IanJ and Dago... it would be quite logical to see a 1.00.3 new version...Could you tell us the date of your version and also could you post it, at least /afg_bin and the drivers?
Just in case hereafter a procedure which won't modify the file attributes:
if you insert a SD:
tar -cvf /mnt/sd/driver /dso/driver
tar -cvf /mnt/sd/afg_bin /afg_bin
or if you connect a usb stick
tar -cvf /mnt/udisk/driver /dso/driver
tar -cvf /mnt/udisk/afg_bin /afg_bin
You could then zip and post the 2 files on your media (driver and afg_bin).
As we already have 2 versions available, you may be able to downgrade to one of them.
IanJ or Dago (or someone having v1.00.2) could you please post your afg_bin and drivers as well ? At the moment I only have V1.00.1. Thanks!
