Author Topic: HANTEK HDG1022A sample code?  (Read 4189 times)
Offline sjsmith274Topic starter
« on: June 13, 2013, 05:42:50 pm »
My company just purchased a new HDG1022A function generator. It works fine in stand alone mode. Using the RS232 interface I can make the included .exe program work (with fidgeting). But I would like to write a BASIC language code and/or operate the unit with a dumb terminal application such as the windows Hyperterminal session. I can't follow the command syntax to make this work, I.e. In a terminal session, 88RS232 does not engage the function generator. But with the Hantek .exe program, if I type this command in the user interface window, I can make it work. But Hantek gives no no source code, just the .dll drivers. Do you have a source code, or better, a BASIC example I could look at.
With Regards,
Steve
Offline tinhead
Re: HANTEK HDG1022A sample code?
« Reply #1 on: June 13, 2013, 06:25:41 pm »
1 - take it apart! Not a joke, i'm really curious what inside.
2- they migrated server (into nirvana) , so maybe the link only broken (http://www.hantek.com/Product/HDG1000A/HDG1022A_SDK.zip)
Create a ticket on hantek.org , they will respond if that was only broken link
Btw, this should be actually MFG3000CH from Gong Chang, Hantek is probably rebadged them
http://product.ch.gongchang.com/d507418739.html
Twintex TFG3500A should be exact the same DDS as well, but they have no SDK on their website :\
http://www.twintex.com.tw/en-us/product/TFG3500ASeries.html
EDIT: yeah, ATTEN ATFxxB seems to be the same as well, at least the same person wrote user manual for all these
models and marked them (as well as the drivers and PC application, lol) as MFG3000CH.
« Last Edit: June 14, 2013, 09:26:04 am by tinhead »
Offline tijaybe
« Reply #2 on: July 22, 2013, 09:27:28 am »
I have an Atten ATF20B .  See attached main PCB pictures.
Panel pictures to follow.
Offline tijaybe
« Reply #3 on: July 22, 2013, 09:29:44 am »
Front panel pictures.
It has a JTAG connector.
Some unpopulated areas.
« Reply #4 on: August 02, 2013, 02:19:02 am »
Thanks for the pictures, I have the RS 232 version, not the usb version of the HANTEK. The pc windows based software works, but I need some help to get it to run in remotely a terminal mode session, say windows hyperterminal.
Regards
Steven Smith
