Author Topic: Hantek DSO5102P - why 2 frequencies?  (Read 184 times)
Offline SparkyNZTopic starter
« on: August 30, 2024, 08:36:13 pm »
I have a Hantek DSO5102P. CH1 is connected to a 28.6MHz signal.
Can somebody please explain why there are 2 frequencies shown? The yellow bar shows 29.58MHz and the blue CH1 frequency only shows 4.996kHz?
I've had a look in the manual https://www.hantek.com/Product/5000P/DSO5000P_Manual.pdf but I can't figure it out.
Screenshot:
Re: Hantek DSO5102P - why 2 frequencies?
« Reply #1 on: August 30, 2024, 08:48:56 pm »
Pulse trigger, right ?
Try a normal edge trigger and drive the scope yourself rather than let Autoset think it knows best.  :horse:
« Reply #2 on: August 30, 2024, 08:51:48 pm »
Yeah you're right. I switched to rising edge and moved the trigger to about 80% of the peak and its now showing only 1 frequency.. and exactly what I expect it to be.
Note to self: If silliness on the screen, forget Autoset. :-) Thank you
« Reply #3 on: August 30, 2024, 08:59:50 pm »
Good work, we all learn a little each day........
« Reply #4 on: Yesterday at 01:03:13 am »
And then forget more the next day :-)
