I need to buy an oscilloscope. Not for professional work. But I need the accuracy of measurement about mV. I saw the videos of Hantec 2000 series models on YouTube. They did not measure accurately at all. They cannot measure below 150 millivolts and they are not accurate in measuring below one volt.
Quote from: kavehm on February 18, 2024, 01:26:24 pmI need to buy an oscilloscope. Not for professional work. But I need the accuracy of measurement about mV. I saw the videos of Hantec 2000 series models on YouTube. They did not measure accurately at all. They cannot measure below 150 millivolts and they are not accurate in measuring below one volt. That's not true. What exactly do you want to measure? DC, 1kHz, 100MHz?It's an oscilloscope, not a multimeter, but imo it measures correctly even in lower volt ranges.Example: This is 2.5mVPP square@1kHz on a DSO2C10
I need an oscilloscope in the working range of kHz up to 5 MHz.
