Has anyone updated to the latest firmware from 2024-05-07 I can find on their website?
What are the outstanding problems with this scope with the latest firmware?
The scope sometimes freezes within 1-2 minutes directly after starting.
However, this is not related to the firmware version (afaik).
If this happens, let it continue to run briefly and then restart it. After the second boot, it will run "forever". I have never had it crash during a measurement.
You can avoid this to a large extent by setting it to default settings before switching it off, so that it is not immediately overloaded at the next cold start (memory depth, persistence etc.).
The good thing is that it starts in 12 seconds. Other scopes need up to a minute for this.
Otherwise it has a few bugs and shortcomings, because it is an extremely cheap scope with a wide range of functions (AWG, protocol decoding, FFT etc.).
In principle it is a $150 scope. You shouldn't pay much more for it.
If you adjust your expectations, it's an amazing device for hobbyists.
Take it for what it is. It doesn't compare to modern Siglents or Rigols, but they don't have anything for $150, not even used (where I live).
If it were a car, I'd say it's perfect for driving to the mall twice a week.
For other requirements, I would go for a more expensive one.
