The next part of the puzzle is the EEPROM contents.
Using Tinheads utility instructions from here:
https://www.eevblog.com/forum/testgear/hantek-tekway-dso-hack-get-200mhz-bw-for-free/msg467313/#msg467313I firstly had a look at the i2c.log file on the / folder of the scope.
It is essentially blank. Anyone know why?
Die Datei '/i2c.log' wurde gelesen. Größe: 8192 Bytes
Die ersten 256 Bytes:
00000| 00 00 00
9F 03 00 00 00 00 00 00 00 00 00 00 00 |................|
00010| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00020| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00030| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00040| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00050| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00060| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00070| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00080| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00090| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000A0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000B0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000C0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000D0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000E0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000F0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
Die letzten 256 Bytes:
01F00| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01F10| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01F20| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01F30| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01F40| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01F50| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01F60| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01F70| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01F80| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01F90| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01FA0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01FB0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01FC0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01FD0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01FE0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
01FF0| 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
Carried on anyway. Connected with USB and connected the Tool, and all the options were 'default', nothing specific looking for my scope at all.
My PCB is my scope is 2012 dated and is Revision 1.00.1 yet is a DSO1152S. HW version is 10010x555583e8.
Based on the Version file, selecting 1001 in the tool would be the wrong move. It suggests 1002 and 1004 are checked for by the firmware. Does anyone have any suggestion as to what mine should be?
My Serial number is DSO06000
xx, so is well above the 15000 threshold, even though its 2012 dated. I purchased it in 2013.
I set the Language to English etc and clicked the write button for the centre section, hoping that it might trigger the scope to update the i2c.log file just from having the language items updated, however nothing happened. In the text box to the right of the tool, it came up with 'failed' shortly afterwards. Wondering if my model is just odd and the EEPROM is somehow different...?
The end game is to try and install the SD and Video functions. I have LAN by default already installed and working.
The next question is where do you obtain the video files to put on the SD card in the first place? I cannot find information on this yet.
Does the card have to be a specific capacity and format?
Another question is around the LAN IP address. Every time I power cycle the scope, my IP address is reset back to default. Is this normal? Is there any way to have it remember the IP address, as its a pain in the butt.
Thanks
