Author Topic: Zeroplus conversion from 16032 to 162000  (Read 2601 times)
Offline DavidDLCTopic starter
« on: September 11, 2013, 07:09:40 am »
Long time ago I converted a ZeroPlus logic analyzer from 16032 to 162000.
I have not fully tested the changes, I have succesfully tested a 5 MHz square signal ( which is the max frequency on my signal generator )
The specs are:
For the 16032:
- Internal Clock (Timing Mode)?100Hz?100MHz
- Memory?512Kbits
- Memory Depth(Per Channel)?32Kbits
For the 16200:
- Internal Sampling Frequency: 100Hz?200MHz
- RAM Size: 64Mbits
- Memory Depth per Channel: 2Mbits
How can I test all these parameters on the converted unit ?
The software recognizes all of them.
David.
Offline eurofox
    • Music
Re: Zeroplus conversion from 16032 to 162000
« Reply #1 on: September 11, 2013, 10:06:32 am »
The specs are:
For the 16032:
- Memory?512Kbits
For the 16200:
- RAM Size: 64Mbits
David.
Was the change only adding or changing memory?
eurofox
eurofox
« Reply #2 on: September 11, 2013, 04:39:47 pm »
I had to change the memory and the eeprom information.
David.
« Reply #3 on: September 11, 2013, 06:22:47 pm »
Should I try to read a 200 MHz clock signal ? I have access to high-end signal generators and more fancy equipment :)
Offline eurofox
    • Music
« Reply #4 on: September 11, 2013, 06:47:06 pm »
David.
You got the contents of the 200 Mhz eprom ?:-DD
Lucky you  :box:
« Last Edit: September 11, 2013, 07:03:15 pm by eurofox »
eurofox
« Reply #5 on: September 11, 2013, 08:12:34 pm »
Reading at the manual, they recommend to measure a frequency 4 times lower than the internal sampling, so I assume testing a 50 MHz clock at 200 MHz sample rate can confirm the conversion.
David.
