I managed to score a 6254BD for $80 on ebay and while I await it to arrive, and cross my fingers I didn't get bamboozled, I decided to research everything I could find about the device, and I found your forum and the hantek support forum in the process. In particular I noticed the below:
Previously, when bricking my scope, I had to ask Hantek for a file (DSO6106BD20160601.iic), but I'm unable to redistribute it since I haven't got permission.
And I also noticed a person on Hantek support forum had an issue with the usb device having the wrong id
I have a problem with the Hantek6254BD oscilloscope. The DRIVER does not install -- but the actual scope software does install.
Can you supply the correct driver? I downloaded the latest software from the Product page for Hantel 6004 page.
Description:
The PID and Device ID appear to be wrong...
So the Scope software installs -- but the driver does not install. If I change the strings to match -- of course the driver is rejected by windows since it does not match the security string in the CAT file.
My device has:
04B5 and 8613 for the two codes -- not the o4B5 and PI_6CDE
My string in the USB identifier -- read from the SCOPE shows as
USB\VID_04B4&PID_8613
Your software is looking for this code.
[Device]
%VID_04B5&PID_6CDE.DeviceDesc% = Section, USB\VID_04B5&PID_6CDE
;for windows 2000 non intel platforms
Which is quite common, so it seems they finally got tired of emailing out that iic firmware to fix usb device issues and their employee Amy just attached it to a
to their post in reply. You have to register to see attachments, but it can be done in less than a minute, I have also attached it to the end of this post. Perhaps it will help some people out here. The iic itself seems to be the same for 0x13FD bytes as the cy_eeprom_dso6074bc.zip firmware posted by neeketos, but neeketos seems to have additional data beyond that.
Screenshot of forum post and partial file listing
If anybody would like to decode the iic file, one way would be to go to section 3.4.3 Serial EEPROM Present, First Byte is 0xC2 of the
manual here. Although there might be better ways, perhaps sigrok has some utilities that automate the process, I don't really know to much about the project other than it seems they are fx2 gurus.
When I get some more free time, I'll continue investigating and will keep you up to date (even if I spend another 2h organizing my findings and writing this post lol). With some luck, I'll clean up the mess of code I've written and will publish it.
While I am on the topic of rgon's post, did you ever publish anything or do any more investigation work?
