Quote from: usao on October 30, 2015, 06:39:42 amIm not able to get the Hantek 6022BE to install drivers on Windows 7.I try the driver install from the driver download, but Windows just sais it's un-recognized.Any suggestions on how to get a working driver for Windows 7?The device is probably drawing too much current that USB can provide, so Vbus is below the device's minimum operating point.I had the same problem with my Owon VDS3102L, until I bought it a much better USB cable.
Quote from: blueskull on October 30, 2015, 07:31:17 amQuote from: usao on October 30, 2015, 06:39:42 amIm not able to get the Hantek 6022BE to install drivers on Windows 7.I try the driver install from the driver download, but Windows just sais it's un-recognized.Any suggestions on how to get a working driver for Windows 7?The device is probably drawing too much current that USB can provide, so Vbus is below the device's minimum operating point.I had the same problem with my Owon VDS3102L, until I bought it a much better USB cable.They supplied a dual USB cable (with both black and red ends). I plugged both in to my windows 7 laptop, and it does recognize a device under the windows device manager.However, all attempts to load a device driver for this "unknown" device have failed. It doesn't recognize the drive folder as containing any valid drivers.
