Latest Binary:
http://jmp.sh/CxPNMVkWhat's New:-----------------------------------------------------------
1. Clicking on Vertical Control Knobs will now select the Vertical Control lists.
2. Fixed a random hang bug.
3. Fixed some Trigger issues.
4. Added an option in Reference Function Generator to select which channel to trigger
Reference waveforms off of.
5. Added a Digital Phosphor/Persistence effect to Display->Waveform->Render menu.
6. Fixed a Lever selection/dragging bug.
7. Implemented FFT Scale in dB option.
8. Fixed an FFT Rendering bug where the generated FFT Image would not stretch to fit
the entire Scope width.
9. Fixed an FFT crash while changing Frequency Bins.
10. Implemented Default Settings Menu Item & Toolbar Button.
11. Renamed some Menu Items and moved a few things around.
12. Implemented the Auto Setup feature (Menu & Toolbar Buttons available).
13. Removed dependance on HTDisplayDll.dll (file no longer required to run).
Notes:1. The Digital Phosphor mode has a "Phosphor Persistence" adjustment which you can adjust in conjunction with the Waveform brightness which will give you more control over the effect. This effect (as well as waveform brightness adjustment) does not work on 64bit Windows sorry, this is due to a Microsoft oversight in their AlphaBlend() API function. Some day I might do my own AlphaBlend function, but not any time soon.
2. The Auto Setup feature is implemented but may not behave exactly like stock software's Auto Setup and it might not do what you expect in certain situations as I have not fully tested it yet.
3. The HTDisplayDll DLL is no longer required to run Open6022BE due to hours of reverse engineering.
Enjoy
