1. Autoset is not taking one to best settings option, on every run it changes the Volt/Div to a different value. On the OEM program the Trigger marker is also set to the middle of the Waveform amplitude. Richard was working on this.
On the Todo, I'll get around to fixing it eventually but lower priority at the moment.
2. Print preview screen underlines the words when typing in Notes. Can the underline be removed? Richard was adding this function.
Also on the Todo, probably be done in next release.
3. OEM software has an Autohide feature for the control panel. Not provided in OPEN6022be yet. Not sure if this is needed or useful to anyone.
I never used the Autohide personally.
4. The OEM software had the date and time displayed at right hand bottom corner, as well as the ”Running” in the left bottom corner. Not displayed in OPEN6022BE.
On the Todo, should be done in next release.
5. On OEM software only the active trigger marker shows, the non-active trigger does not show, but OPEN6022BE shows all the triggers whether active or not. Not sure if this is intentional or not.
I intentionally did it this way because sometimes I like to adjust both triggers then toggle between them, it's just a pain to have to change trigger sources just to adjust the trigger level.
6. Does not keep GUI settings yet, if you close and reopen later. Not sure if it should, but also does not stay in Demo mode if you shut down and restart, but the settings part seem to work now! When closing down while rendering Phosphor persistence, it restarts in Phosphor mode correctly, but then incorrectly indicates that it is in Normal mode.
Demo mode is enabled automatically if no device detected, you can manually enter the mode from the Acquire menu. About the Phosphor mode bug, will be fixed in next release.
7. The zoom function cuts off after 19 steps, but the counter can be clicked up into the hundreds.
The cutoff point varies... It depending on the timebase, it has to do with the DrawWaveInYT function. Hantek's implementation has limits on zooming past certain points... I'll think of something more ideal eventually
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
8. In XY mode the second source pointer which stays horizontal (incorrectly) still needs to be moved to vertical top when in XY mode. (In hand with Richard)
Also on the Todo, it's not as trivial as it sounds to implement it, but if not next release should be done by the following... I just want to implement it in a way that isn't hackish as I never intended there to be levers on the Top Pane (doh).
9. Display Ch1 Ch2 and Reference wave as square wave. Select Trigger sweep Normal. Move reference wave trigger position marker to the lower part of the reference waveform. Ch1 and Ch2 suddenly goes off the screen to the top.
Will look into this.
10. Reference wave was out of phase with internal 1k waveform, now nearly in phase, but square wave shows it is still out by a small margin.
Internal waveform has offset due to noise causing premature triggering, Reference wave & Demo Mode waves are pure, so they trigger exactly on wave edge.
11. Can select Reference as trigger even if Reference waveform is off. Reference shows 500mV while Math selected as trigger when off shows 0V.
Will check this out also.
12. Right click on waveform marker and a pop up Hide box comes up and if cursor is over marker it switches the channel off. But Hide can be right clicked anywhere in this left margin still displays popup, which does nothing obviously.
I'll make the option grayed out if there isn't a Lever under the cursor.
13. Left clicking mouse cursor anywhere on screen gives Ch1 and Ch2 voltage readings in a small box which corresponds to whatever position the mouse cursor is. Not sure if this is intentional or what it is supposed to be doing?
It's not actually on left click, it's a popup hint that usually triggers on left clicks, but it's just a quick and dirty measurement (similar to Cross cursors).
