One more thing, if you do the AWG mod you will need to calibrate the amplitude of the waveform, there is no need to play with the resistors values as someone posted some time ago. Just install the FW linked below using Dfuse. Use a coax cable to connect Gen Out to CH1 of the device, go to the AWG and set Sine wave, on the second page of the configuration you will see an option "calibrate", select it and it is done. You can now update to the last firmware again.
So you mean:
- change 0 Ohms resistor at the output of the OpAmp to 50 Ohms
- change 0 Ohms resistor at pin 3 of OpAmp to 150 Ohms
- change 0 Ohms feedback resistor (at OpAmp left side) to 560 Ohms
is
NOT necessary , right?
I downloaded the instructions from jace@cs on page 6 of this threat. I only changed R65 to a lower value as my first dac was not working/responding. In case you need the passive smd's, I have some spares as I ordered to much. I can send them to you if you pay the stamp (I live in the Netherlands) The ST-link and ic's I found on ebay/ali. By the way : the dac903 is a 12 bit dac...
Thanks for the offer.. I'm in germany so this would be somewhat possible and welcome.
For my understaning: EL5166, BAV99 are also necessary, are they included in your offer?
To be honest I just like to work with PCB stuff. I don't know when I ever will use AWG but this would be some option than...
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
St-link is already ordered.
