Author Topic: Handheld Oscilloscopes  (Read 8012 times)
Offline WanaGoTopic starter
« on: May 23, 2013, 11:26:19 pm »
Hello All
I am looking for a decent handheld oscilloscope, and just wanting to know if anyone has any input of good/bad otherwise.
Mainly using it for bench testing, however also for in the car and various things out and about. I know for equivilent money I could get a nice bench scope, however would prefer the portability.
I came across the SIGLENT SHS810, and the SIGLENT SHS1102, along with the Hantek DSO1102B and Hantek DSO1202B. There are a few others too.
I think I am mainly interested in the SHS810.
Anyone know much about them? Good/Bad etc?
I found this youtube review, however its in Russian, but it seems to give a fairly good overview on what the unit looks like and displays like: ??????????? ???????? ??????????? SIGLENT ????? SHS800
Any input would be appreciated.
Thanks
Re: Handheld Oscilloscopes
« Reply #1 on: May 23, 2013, 11:33:07 pm »
I also just found Sigilent SHS815 and the Sigilent SHS820, but it seems the SHS820 has less memory depth.
http://www.tester.co.uk/downloads/dl/file/id/113/shs800_series_datasheet.pdf
« Last Edit: May 23, 2013, 11:36:22 pm by WanaGo »
Offline rolycat
« Reply #2 on: May 24, 2013, 12:31:45 am »
mikeselectricstuff has a review of the Owon HDS3102M-N here:
There's a teardown too:
« Reply #3 on: May 24, 2013, 01:26:34 am »
Thanks,
Watching the vids now.
Just realised the SIGLENT scopes are quite bad for sample rate with dual channel... hmm.
Looking again and I see the Hantek DSO has a BV range which has 1M memory compared to the Kb the B range has. That puts it back in the spotlight for me a bit.
Hantek also has a higher screen resolution over the SIGLENT.
Will take a look at this Owon one in more detail now.
« Last Edit: May 24, 2013, 09:07:06 am by WanaGo »
« Reply #4 on: May 28, 2013, 09:38:56 pm »
Decided to go with a Hantek DSO1152S+LAN option, which is a 150Mhz handheld, 1M Memory, 1GS/s etc, Isolated inputs to GND and between channels.
Will see how it goes when it arrives.
Offline rf-loop
« Reply #5 on: May 29, 2013, 09:06:51 am »
Can you explain this your changed thruth....
As far as I know 60, 100 and 150MHz models have
For normal memory, realtime samplerates
max 1GSa/s for 1 channel with 40k memory
max 500MSa/s for 2 channels with 20k + 20k memory
For long memory
max 500MSa/s  for single channel in use  2Mpoints memory  (example Hantek 1M if even it is true)
max 500MSa/s  for both channels simultaneously   and 1M + 1M memory (example hantek 500k+500k)
This smaller memory leads to slower samplerate with slower horizontal speeds.
what is now "quite bad"?
EV of course. Cars with smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
