Just to clarify, the "software" being spoken of here is more related to the specific automotive tests that are built into the pico software, such as the starting and charging test that can detect battery, starter and alternator issues, cylinder balance and compression tests, can bus decoding and much more.
Yep. I'm fairly sure a "bench scope" doesn't have 150 guided tests built in for automotive diagnosis.
https://www.picoauto.com//library/automotive-guided-tests
That's the added value I'm referring to. It's what you're paying for, not the 'scope hardware.
And a library of thousands of good/bad waveforms to compare to...
Freely available online. Let's not forget that any tech that needs them REALLY shouldn't be blowing money on something so expensive when something much cheaper will work.
And also, auto electricians I know have more laptops and computers than wrenches...
Everything is PC (laptop) based. From service manuals, to all kinds of programmers, CAN/LIN diagnostics, ..
Any technician with more computers than wrenches is a bad tech. You don't care why comms aren't working internally. It goes like this usually... No comms with 1 or more control units. Check powers and grounds on affected modules. Check for shorts to power/ground on data lines, no shorts? Replace affected units. Shorts? Disconnect affected modules and recheck, no shorts? Reconnect modules rechecking bus until you find faulty unit. Shorts? Find short in harness. Occasionally you need to diagnose a faulty module causing issues on bus so you monitor with scope, typically just for glitches, while taking modules out of the loop.
Also in the electronics lab, I have several PC based instruments (2 USB scopes and SA, several USB logic analyzers.).
It takes less space, 24" (touch) screen beats any physical instrument, and it makes saving data easy. I have a dedicated PC for it and it works great.
This is fine for a mostly fixed lab, not for a highly dynamic workspace.
Well I had a situation where the can bus would go bad intermittently.
Checking wiring found no rub marks etc.
The Pico automotive scopes come with long test leads so you don't have to be right next to where you are measuring.
I was able to find the exact cause of the fault very quickly once I hooked up the scope to the can bus.
Sure, this could have been any battery powered scope, but I already have the laptop with me as the OEM service tool.
I could have used any half decent scope to do that same job, but the pico is what we have and is supported and recommended by the OEM.
The built in tests and tutorials are great because many automotive mechanics are not familiar with a scope and struggle with a multi-meter. So it can guide you. The compression/balance and starting tests are quite nifty too.
Ive used the scope with a current sensor(supplied in kit) to find intermittent shorts and also to find broken wires in a loom, bad connections in plugs, bad earths, find internal mechanical faults, hydraulic pressure testing, confirm dead sensors and even find/confirm software faults. I could use any half reasonable 4ch portable scope as I don't need the tutorials and reference waveforms due to understanding the sensors and systems I am working with and could make test leads as required, but for a workshop something like the pico automotive scope is great because it comes with everything you need(long leads, current sensors) to do most of the testing you will need to do with it along with the tutorials that will help you save time if anyone is game enough to touch it!
As James_S said, most of the electrical faults I find are damaged wiring, corroded connectors and bad sensors, in that order.
