Author Topic: Hakko T14 (936) tips  (Read 3615 times)
Offline stazeTopic starter
  • I _might_ have a problem...
    • Everybody Staze...
« on: March 19, 2014, 09:45:40 pm »
Anyone know where to get tips for the Hakko 936? I just inherited one, and the tip is in a bad way... would like to replace, but all I can seem to find are cheap chinese versions.
“Give a man an answer, he’ll keep his job for a day. Teach a man to Google, and he’ll be employed for a lifetime”
Offline neslekkim
  • Country: no
Re: Hakko T14 (936) tips
« Reply #1 on: March 19, 2014, 10:45:59 pm »
936 uses 900m tips, you get them for nicels at ebay, and I guess they should be good enough.
T18 is the name of the 888 tips, T14?, what is that?
Online mariush
« Reply #2 on: March 19, 2014, 10:51:58 pm »
The FX-888 tips are compatible with the Hakko 936 tips. There's maybe just a few mm difference in the length (in real world, maybe the temperature would get get offset by a few degrees C)
These should be original Hakko:
https://www.sparkfun.com/products/10721
https://www.sparkfun.com/products/10720
https://www.sparkfun.com/products/10719
This ebay seller (who claims to be authorized Hakko distributor - you can check on Hakko website when it works) has several other models along with the 936 tip code they replace in the title of each listing:  http://stores.ebay.com/NEI-Lamps-and-Electronics/HAKKO-SOLDERING-TIPS-/_i.html?_fsub=4&_sid=82105093&_trksid=p4634.c0.m322
Offline Nerull
« Reply #3 on: March 19, 2014, 10:54:29 pm »
Which tips you use depends on the hand piece - there were a few available for the 936. The most common was the 907 which takes 900M series tips, which have been replaced by the T18 series tips used by the FX888 - Hakko doesn't list them as compatible but they are essentially identical and lots of people use them.
« Reply #4 on: March 19, 2014, 10:55:40 pm »
Huh. Hakko says to use T14 tips (https://www.hakko.com/english/n2system/connection-method-03.html)... didn't know the T18 was compatible.
Cool... T18's are easy to find.
« Reply #5 on: March 19, 2014, 10:56:19 pm »
Cool. Yeah, handle is the 907... so should be good to go.
Thanks!
Offline Nerull
« Reply #6 on: March 19, 2014, 10:57:42 pm »
T14 tips are for the 938
Offline neslekkim
  • Country: no
« Reply #7 on: March 19, 2014, 11:05:29 pm »
I have used 900m and t18 on the same iron, what's the differece?, only another stamp.
Offline neslekkim
  • Country: no
« Reply #8 on: March 19, 2014, 11:08:21 pm »
And 957 handpiece?
« Reply #9 on: March 19, 2014, 11:13:04 pm »
oh, and if you look a different way, you can see the T18 tips are compatible with the 936. Ugh... Hakko needs to fix their site.
