Author Topic: 8563E problem  (Read 1731 times)
Offline chipsoTopic starter
  • Country: at
8563E problem
« on: May 22, 2019, 08:13:23 pm »
I have problems with my 8563E.
Turning on sometimes takes about one minute or a little more until the CRT lights up.
(seems it takes longer and longer)
the boot process is over until I see the glow of the tube.
(If I turn off the 8563E after the start - and again on - it takes about 20 sec - then i can see the boot process.
Has anyone already observed this, or does anyone have tips to prevent a worst-case
(sorry for my small english)
Thank's
John
Offline SoundTech-LG
Re: 8563E problem
« Reply #1 on: May 22, 2019, 08:25:57 pm »
I don't know about you, but I tend to keep intensity low. I see a similar issue with my 53310A.
If you haven't, try giving the intensity a boost. Probably needs more the older it gets...  like the rest of us :)
  • Country: at
Re: 8563E problem
« Reply #2 on: May 22, 2019, 08:45:09 pm »
The CRT is sharp and bright. (brightness is 25)
The HP 8563E only has an operating time of 5200 hours.
john
