After a bit of
, we did manage to activate all the licenses on the MSO8204. None of this would be possible without the help of
BTO and
DrMefistO.
I am not sure it will work on 8000A's but the script can be modified to accommodate that. I will try to update the script in the near future in order to upgrade the bandwidth as well (e.g. from MSO8064 to MSO8204)
In order to activate the MSO8000 you need to create a temp dir, download the attached script to the temp dir and than cd to temp dir.
1. python rigol_mso8000_kg.py -r <mso8000_ip>
# this will generate a .priv file. do not delete it
2. reboot scope (REALLY IMPORTANT) -> wait for the scope to be up and running again
3. python rigol_mso8000_kg.py <mso8000_ip>
4. done
##notice the second time you need to run it without -r
