Is the Version 01.03.02.02 that was used sucessful available somewhere to download?
@BTO, if you have the 01.03.02.02, could you provide that on your Mega drive please?
Thanks a lot, Seppeltronics
Ask and you shall receive....
LINK TO VERSION 01.03.02.02 AND 01.03.03.00
https://mega.nz/folder/A8cEgQRI#5FSoMrCurJi71T7VkRPgYQ
Quick update to this post of mine
Update 1 - I have deleted my last post as i no longer require the 1.3.2.2 upgrade file, I have worked out the problem.
Update 2 - the 1.3.2.2 Gel file at the link i have supplied is 100% good , verified and working
My scope until today was on Version 1.3.3.0, Upgraded
VIA PATCH and all options unlocked.
I can confirm that i downgraded (using the file at the link)
From 1.3.3.0 to 1.3.2.2- After the downgrade of firmware version - I LOST ALL THE OPTIONS
The firmware version did reflect that i was now on 1.3.2.2I tested this 5 times over and i can confirm that even when you downgrade (as you would logically conclude) You can absolutely upgrade back again and re patch if need be.
THE PROCEDURE TO FOLLOW IS AS FOLLOWS (it's pretty simple)
I am also going to put a video at the same location as the link i have supplied for the Gel File
1. ACCESSING THE PRE-BOOT MENU (What some have called "The Hidden Menu)"
in the Pre Boot Menu you get 2 options
UPGRADE FIRMWARE
RESTORE DEFAULTS
To get to this point you
1. Start with the scope OFF
2. Turn the scope ON and Immediately and REPEATEDLY Press the "SINGLE" button (Say approx 2 presses per second) you don't need to be highly accurate, Just not too slow.
2. DOWNGRADING TO 1.3.2.21. Download the file from my link here
https://mega.nz/folder/A8cEgQRI#5FSoMrCurJi71T7VkRPgYQ2. Get the file, Extract it and put ONLY THE .GEL FILE in the root of a USB stick (Formatted FAT32)
3. Follow the procedure in point 1 BUT SELECT "RESTORE DEFAULTS" (It's not necessary, but.. Be on the safe side)
4. Turn off your scope after step 3 has completed
5. Follow the procedure in point 1 BUT SELECT "UPGRADE FIRMWARE"
IF IT FAILS - All the lights will flash and the bottom of the screen (Within 10 seconds) will say "Upgrade failed, Please check file" (i would check that you extracted it and i would try another USB)
IF IT SUCCEEDS - the bottom of the screen will say "Upgrading please waitting" (no that's not a spelling error , that's what it actually says) , then it will say ... Successful.
Wait 10 seconds then... Restart the scope.
6. After this restart the scope and you'll see that your options have disappeared and that your scope version is now 1.3.2.2
Only catch is.. You cannot downgrade the version from the Local Upgrade option within the O/S, it must be done from the Pre-Boot Environment
Let me know if you have any issues.
Beyond that, i'm going to try to get this Dr Mefisto method working and make a video for it. At least we now know we can try the method without fear of not being able to re patch again.
