Try to uninstall all options first, wait for reboot, then install with regen private key flag.
I tried as described, first uninstalled and after reboot I installed with regen private key. Tried it several times but the oscilloscope only replies with "remaining attempts" as described by zauberpilz, now only 2 attempts left. What am I doing wrong? Could you please help?
OK, in light of all the conversations i've had recently, I'll ask you this
WHAT ARE YOU TRYING TO ACHIEVE ?
if the answer is ... You want to unlock the full features of your MSO5000 then
My previous answer used to be , Go to this link
https://www.eevblog.com/forum/testgear/post-hacking-rigol-mso5000-post-hacking-tutorial-deep-dive/Download the upgrade zip file and video 2, and it'll happen without a problem, Absolutely everyone that has tried the method i'm doing
(which really is the method that the forum is doing, except i put it in folders to make it easy and made a video to show you how to do it)
it's not mine , Credit goes to those that unlocked it. Just to be clear.
Now...
IN SAYING THAT
I have recently been told the following
- The Method of doing that i just told you that works , Even though it says "FOREVER" and all options unlocked
I have been told that this does not mean that it's properly licenced.
Apparently this only becomes an issue when it comes to future updates . but You will have all options unlocked and you will have no problems
on the update that you're on and you will be updated to version 1.3.3.0
- The method you are doing as prescribed by DrMeFisto (that i have absolute respect for) has been told to me that it's touch and go.
Just like you , many people have struggled to get it done, the Positive side of it is.... IF IT WORKS, (This point keeps getting repeated apparently, ) is that your scope will be properly licenced and you won't ever have to worry about unlocking it again. you can just upgrade
as normal and the licenses will be preserved
but again, so.. what are you trying to achieve
JUST GET THE SCOPE ALL UNLOCKED
or
GET IT PROPERLY LICENCED SO YOU NEVER HAVE TO WORRY ABOUT PATCHING IT IN THE FUTURE ?
FYI - I do plan to try DrMeFisto's method, although it probably won't happen for at least a month,
but even then... I have over 100 people that i have successfully updated through the method i presented.
even if my scope licenses correctly through DrMeFisto's method, i can't guarantee that that will mean that your one will, Considering
that so many people have no been able to do it .
so there is a secure option of doing it that works well, But TECHNICALLY it doesn't "properly" licence the scope, although you'll never notice the difference
and there is a method of doing it properly which is a lot harder
if you wish to choose the latter option then you'll have to wait till i try it and i'll make a video on it.
My scope is currently all unlocked and it's my understanding that by DrMeFisto's method i can revert my scope to factory and then update it properly, IF THAT'S THE CASE, i'll let everyone know
so ,WHAT WOULD YOU LIKE TO DO ?
