Hello to all!
I became the owner of Rigol MSO5074
Firmware: 0A.01.03.00.01
Hardware: 01.01.000
Boot: 2018.06.27
Build: 2021-05-04 15:50:32
I made a backup in three different ways
Method №1 - Through SSH
Opened an SSH channel in the oscilloscope
described
here #878Now you can connect a PC to the oscilloscope via LAN
this feature remains until the oscilloscope is rebooted
To connect, you need to install the PuTTY program on your PC
Used the commands:
Create a backup (copy all files, including licenses)
mkdir /media/sda1/calib_backup
cp -v /rigol/data/* /media/sda1/calib_backup
sync
Copy Calibration (Calibration files only)
cp -v /media/sda1/calib_backup/*.hex /rigol/data/
sync
calib_backup folder will appear on the USB drive (27 files) - size 2Mb
Method №2
The method is described
here #1384The process lasts 60 seconds.
folder and file will appear on the USB stick:
- backup folder (28 files) - size 2MB
- memdump file - size 469 762 048 bytes
Method №3 - NAND
here #1384The process lasts 04m. 19 sec. (259 sec.)
The following files will appear on the USB drive:
- file mtd0_Env.bin - size 262 144 bytes
- file mtd1_DATA.bin - size 67 108 867 bytes
- file mtd10_App2.bin - size 104 857 600 bytes
- file mtd11_Reserved.bin - size 70 254 592 bytes
- file mtd12_User.bin - size 628 621 312 bytes
- file mtd2_Bmp.bin - size 4 194 304 bytes
- file mtd3_Bmp1.bin - size 4 194 304 bytes
- file mtd4_Bit1.bin - size 8 388 608 bytes
- file mtd5_Sys1.bin - size 35 554 432 bytes
- file mtd6_App1.bin - size 104 857 600 bytes
- file mtd7_Bmp2.bin - size 4 194 304 bytes
- file mtd8_Bit2.bin - size 8 388 608 bytes
- file mtd9_Sys2.bin - size 33 554 432 bytes
Total capacity 1,047,296,000 bytes (1 GB)
We see that the result of work in each method is different
which method is the most correct?
How can I restore the oscilloscope based on the files from each method?
Thank you!
