It seem to be a legit location.
I didn't think about it, I ordered 5072.
But I would like to buy 1:10 probes on the 500MHz
https://aliexpress.ru/item/1005004828373989.html?
Succesful upgrade here! Thanks!
Hi guys, I upgraded my oscilloscope perfectly well and smooth. I made a guide to help all the users to get through the upgrade process.
I hope you can find it useful and of course, any suggestion to improve the guide will be very welcome.
https://www.mediafire.com/folder/zh1uiu3umgoai/Documents
I uploaded to mediafire because I can't share them here. The firmware.rar files contains all the files needed to work with the guide. The Word file is the guide with images.
Thanks a lot!!!!
Hi! The link is no longer working, who has this information on the link?
Thanks a lot!!!!
I just tried the link above. There are two files for download. A word document and a file with the patched firmware.
I checked for viruses, all clear. Now I am reading the word document. I didn't patch it until now.
Update: I just did the firmware upgrade and patch according to above. It all works. Now I have the newest firmware and all options.
Thanks a lot to everybody!
Fairly new here. Obviously, lujji was able to read through this thread and create a patch for the previous fw version even before owning the scope, so I started to read too... I'm only up to mid-2019 when the ideal of using a patch file surfaced after SSH was removed by Rigol... Surely, there's got to be a better way to summarize the knowledge of this thread and how to create patch files without having to read the entire history, right?
Thanks a lot!!!!
Hi faktorqm,
Great work done sorting it out and do such a detailed explanation.
Just one question to clarify from the guide at the beginning:Quote"Have an ethernet network wire to connect it directly to your computer. "
Do you connect ethernet cable to the oscilloscope through router or the connection was done directly - from oscilloscope to PC? If it is direct connection to PC without router, did you use LAN crossover cable or LAN straight through cable?
Thanks!
I did start to go down the path with Ghidra, but I didn't know which specific changes needed to be made. I'm definitely not trying the hard way. I just haven't gotten through the entire thread yet to find the most recent, easiest way, I guess.
You can't use the old bspatch with the latest firmware because one of the functions moved. Try this one. Be warned I have not tried it myself so if someone that knows what they are doing (ie. you can recover) can verify first that would be great.
I don't know why you guys are using the hard method like objdump to figure out patches when there is Ghidra.
Tried the patch here. Seems to work OK, will report back if/when something changes, but so far everything good.
I finally had a chance to try it myself and I can also confirm it seems to work fine.
