Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 1145397 times)
0 Members and 22 Guests are viewing this topic.
Offline JCS666
    • ea1dzl
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #2475 on: March 07, 2023, 10:22:52 am »
OK, sorry
I see that you are Spanish, I hacked my rigol at the beginning as soon as the valid hack appeared, but seeing your guide I sensed that another method could be followed, it would be a lot of trouble to also put it in Spanish, my command of English leaves much to be desired, thanks in any case case.
Offline williamlee
  • Country: tw
« Reply #2476 on: March 17, 2023, 10:26:15 pm »
I can't find any 1.3.2.2 FW upgrade file on the Rigol website????  :-//
Online thm_w
  • Non-expert
« Reply #2477 on: March 18, 2023, 12:23:01 am »
Its mislabeled on some of the rigol sites, you can also find it a few posts back.
Offline apolkosnik
« Reply #2478 on: March 20, 2023, 04:19:47 pm »
Is there a way to unbrick the scope without opening it up? I took out my MSO5102 out of a box lately (it was working perfectly before), and powered it on. It hangs with a black screen without showing a boot screen now, any clues? Thanks in advance!
Online thm_w
  • Non-expert
« Reply #2479 on: March 20, 2023, 09:17:33 pm »
So pressing "single" does nothing then? Everything other than power unplugged from the unit?
Is it still under warranty?
Offline Mandragora
« Reply #2480 on: March 22, 2023, 06:07:13 pm »
Hello guys, I was going to share my experiences of upgrading my "brand new" MSO5074 for more data points. but before that I stumbled on...
I've ordered my scope from Batronix on 29.12.2022, roughly 3 months ago. Yea, that is long...
Today I powered the scope for 1st time after delivery (today). To check my firmware version I opened "System Information". Firmware is 1.3.0.3, but to my surprise bottom text says -> "Build: 2021-10-18"
Did I really waited 3 months to receive 17 month old scope? Should call out about that to Batronix and request replacement? Or just leave it be?
P.S. Is there an easy way to remove Warranty Void sticker to replace fan for a Noctua?
Offline skander36
« Reply #2481 on: March 22, 2023, 06:34:36 pm »
This is the firmware version build(compilation) date.
Most important is the calibration date, which should not be more than 6 month old.
The following users thanked this post: Mandragora
Offline apolkosnik
« Reply #2482 on: March 22, 2023, 08:20:47 pm »
Thanks! It seems like the flash memory kicked the bucket. Thankfully, it was still under the warranty.
Offline Mandragora
« Reply #2483 on: March 22, 2023, 08:36:30 pm »
Thanks skander36, It is same date and time as on System Info of others users with 1.3.0.3 firmware. I just remembered that I saw newer build date (around 12.2022) but it turns out to be 1.3.2.2 firmware.
My calibration date is 06.01.2023 so not that old. I was worried that I got old stock as a "new" device.
It is a little weird to me that firmware build =/= firmware version (aka one firmware version shouldn't have more than one build date? so there would be no reason to differentiate those). But I am not a software developer.
Thanks again.
Offline shoehorn81
« Reply #2484 on: March 23, 2023, 10:48:16 pm »
I would be interested in sending my MSO5074 to someone to have them hack it for me.  Paying of course.  Any interest?
Offline Mandragora
« Reply #2485 on: March 24, 2023, 11:04:58 am »
Hello guys,
I've successfully updated firmware and applied upgrade to my scope yesterday, no hiccup's.
I used brand new SanDisk 3.1 Flash Drive (32GB) which was formatted as FAT32 as default.
@shoehorn81 hack is fairly simple, if you need guidance I could walk you trough it, for example on Discord. PM me if you want to.
Regards
Offline shoehorn81
« Reply #2486 on: March 25, 2023, 07:31:06 pm »
@Mandragora I was able to install the patch.  I must admit I was a bit intimidated by 100 pages in this forum.  About 1/2 way through there is a patch download.  Simple as putting that on a thumb drive and and installing.  Big thanks to all that made this possible.
Offline mcalderon
« Reply #2487 on: March 26, 2023, 06:34:35 am »
Hello, Can you guys help pointing me to how to upgrade the firmware. I want to hack this oscilloscope but I am scared to do it wrong. Is faktorqm guide the best/most recent guide to follow? If now is it possible to give some guidance?
Offline williamlee
  • Country: tw
« Reply #2488 on: March 29, 2023, 05:15:45 pm »
"Hello, Can you guys help pointing me to how to upgrade the firmware. I want to hack this oscilloscope but I am scared to do it wrong. Is faktorqm guide the best/most recent guide to follow? If now is it possible to give some guidance?"
1. upgrade the official FW at the first moment to the last ver.
2. After you upgraded the new official FW as the base on your upgraded version number to go to the "Local" to upgrade your "hack version".
Simple and easy.
Offline vadimcreates
  • Country: md
« Reply #2489 on: April 01, 2023, 12:27:25 pm »
Hi guys, I upgraded my oscilloscope perfectly well and smooth. I made a guide to help all the users to get through the upgrade process.
I hope you can find it useful and of course, any suggestion to improve the guide will be very welcome.
https://www.mediafire.com/folder/zh1uiu3umgoai/Documents
I uploaded to mediafire because I can't share them here. The firmware.rar files contains all the files needed to work with the guide. The Word file is the guide with images.
Thanks a lot!!!!
Hi faktorqm,
Great work done sorting it out and do such a detailed explanation.
Just one question to clarify from the guide at the beginning:
"Have an ethernet network wire to connect it directly to your computer. "
Do you connect ethernet cable to the oscilloscope through router or the connection was done directly - from oscilloscope to PC? If it is direct connection to PC without router, did you use LAN crossover cable or LAN straight through cable?
Thanks!
« Last Edit: April 01, 2023, 12:29:41 pm by vadimcreates »
Offline w.v.s.
« Reply #2490 on: April 01, 2023, 01:49:49 pm »
Thanks!
Consider it just as a computer. Use a regular cable, if you connect it to a router or a crossed one, if you connect it do your PC directly. I did the direct connection with a crossed cable, because I wanted to make it harder for it to call home.
The following users thanked this post: vadimcreates
Offline mwb1100
« Reply #2491 on: April 01, 2023, 05:56:58 pm »
Most network interfaces today support "Auto MDI-X" so a crossover cable should almost never be necessary (Gigabit Ethernet links don't need crossover by design)
  - https://en.wikipedia.org/wiki/Medium-dependent_interface#Auto_MDI-X
Offline ytterligare
« Reply #2492 on: April 02, 2023, 02:45:58 pm »
Hello there,
I read through quite a lot of messages, but still not sure about this, as most of you seems to be "fixing" a "virgin" MSO5K...
My MSO5K is a 5072 at :
Firmware : 00.01.03.00.01
Hardware: 01.01.000
Boot: 2018.06.27
Build: 2020-03-30
And it is already "hacked" to get full power "Forever"
Is the method in "faktorqm" guide ok also for already modified device ? I feel I'm a couple of version behind with the software but I wouldn't want to lose all the gained perks, so to speak...  8)
Thanks
A.
*** EDIT ***
Nevermind, I read better the documentation : the procedure reset temporarily the MDSO5K to the default, ( hence losing all the pre-existing "fixes" ) before applying the final patch
Anyhow I successfully upgraded and re-enabled the Rigol "fixes", following the guide : many thanks !!!   :-+
« Last Edit: April 03, 2023, 08:51:19 am by ytterligare »
Offline Andrey_Ak
  • Country: kz
« Reply #2493 on: April 05, 2023, 09:41:33 am »
Hello comrades!
I want to purchase Rigol MSO5072, are there any ways to hack it before MSO5354? And will all 4 channels work?
Offline skander36
« Reply #2494 on: April 05, 2023, 10:11:52 am »
Hello comrades!
Yes, read the thread.
The following users thanked this post: Sighound36, Andrey_Ak
Offline ytterligare
« Reply #2495 on: April 05, 2023, 02:49:50 pm »
Yes, mine was precisely a MSO5072 and got it working as an MSO5354, see my post below/after...
The following users thanked this post: Andrey_Ak
Offline Andrey_Ak
  • Country: kz
« Reply #2496 on: April 06, 2023, 02:38:44 am »
Thanks a lot!!!!
Hi!  The link is no longer working, who has this information on the link?
Offline Fungus
« Reply #2497 on: April 06, 2023, 03:31:34 am »
Hello comrades!
Yes.
The 5074 has two more probes in the box though, if you don't have any then a couple of 350MHz probes will cost about the same as the difference.
Offline Andrey_Ak
  • Country: kz
« Reply #2498 on: April 06, 2023, 05:01:14 am »
I didn't think about it, I ordered 5072.
But I would like to buy 1:100 probes on the 250MHz
https://aliexpress.ru/item/32350679999.html?
But I would like to buy 1:10 probes on the 500MHz
https://aliexpress.ru/item/1005004828373989.html?
« Last Edit: April 06, 2023, 07:19:09 am by Andrey_Ak »
Offline idolclub
« Reply #2499 on: April 11, 2023, 02:08:32 pm »
Rigol releases new firmware v00.01.03.03.00 for MSO5000 ~ 2023.04.10
Firmware v00.01.03.03.00 Release Notes:
[Supported Model]    All the MSO5000 Series Digital Oscilloscopes
[Latest Revision Date]  2023/02/22
[Updated Contents]
v00.01.03.03.00  2023/02/22
  - Patch for MSO5000 nand-flash new material
  - add function operation Gain and offset setting query command in symbol AX+B
  - the vertical minimum gear is restored to 500 microvolts
v00.01.03.02.02  2023/01/04
    - Add shortcut button and VNC remote function
    - Waveform, cursor movement, gesture operation vertical and horizontal gear switching speed optimization
    - Cursor optimization: cursor jump optimization, ZOOM area and main time base cursor linkage, etc
    - The color of the CH4 waveform is modified, and the brightness of the waveform is improved
    - ZOOM mode optimization: mask color adjustment, switching speed, area movement optimization
    - SCPI instruction response speed optimization: reset, measurement, waveform read instruction response optimization
Download:
https://supportcn.rigol.com/Public/Uploads/uploadfile/files/ftp/Firmware/DS5000(ARM)Update%20v00.01.03.03.00.zip
The following users thanked this post: thm_w, ytterligare, skander36, MegaVolt, Varz, w.v.s.
