Rigol releases new firmware v00.01.03.02.02 for MSO5000 ~ 2023.01.09
Firmware v00.01.03.02.02 Release Notes:
[Supported Model] All the MSO5000 Series Digital Oscilloscopes
[Latest Revision Date] 2023/01/04
[Updated Contents]
v00.01.03.02.02 2023/01/04
- Add shortcut button and VNC remote function
- Waveform, cursor movement, gesture operation vertical and horizontal gear switching speed optimization
- Cursor optimization: cursor jump optimization, ZOOM area and main time base cursor linkage, etc
- The color of the CH4 waveform is modified, and the brightness of the waveform is improved
- ZOOM mode optimization: mask color adjustment, switching speed, area movement optimization
- SCPI instruction response speed optimization: reset, measurement, waveform read instruction response optimization
v00.01.03.00.03 2021/10/18
- Optimized waveform display in XY mode.
- Optimized the DC gain calibration algorithm.
- The La channel is decoded in parallel, which solved the problem of decoding error in negative polarity.
Download:
https://supportcn.rigol.com/Public/Uploads/uploadfile/files/ftp/Firmware/MSO5000(ARM)Updatev00.01.03.02.02.zip
