Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 1123219 times)
wickeLine228 and 29 Guests are viewing this topic.
Offline zzzox
  • Country: ru
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #1925 on: December 31, 2020, 05:04:21 am »
Hi
My scope : MSO5072   01.03.00.01   hw 01.01.000 2018.06.27 2020-05-18
Omgoleus files worked.All option is unlocked forever.
Simply local upgrade from flash drive.(Kingston Data Traveler 100 G3 32GB Fat32).
MSO5000 with all option is great  oscilloscope.
Thanks to Dave and everyone on the forum  :)
B.R.
The following users thanked this post: whatisthis
Offline luky315
  • Country: at
« Reply #1926 on: January 02, 2021, 11:12:36 am »
I find still interesting that a lot of people are installing a script "from the internet" without any idea what this script is changing or how.
Offline tv84
  • Country: pt
« Reply #1927 on: January 02, 2021, 12:41:36 pm »
See the definition here.
Did you create your own software? BTW, with tools "from the internet"?
« Reply #1928 on: January 02, 2021, 02:16:49 pm »
Many people are driving "cars from a garage" while being blissfully ignorant of the operation of internal combustion engines. Not everybody knows, or even wants to know, or is capable of knowing, the exact internal workings of everything they use. There are risks in that ignorance at all levels and there are opportunity costs in acquiring the knowledge to make any action relatively risk free. Between the two extreme states, people make trade-offs.
The following users thanked this post: Protegimus
Offline nh90wxr
« Reply #1929 on: January 13, 2021, 09:48:12 am »
After heavy struggling the last days I have got success at the end, but only when I re-installed the already available fw 00.01.03.00.01 into my MSO5074, which I freshly received in the cw 1/2021. The fw in the item with build date 2020-05-18 (e.g. missing sshd) did not accept the 1301 patch - see picture with error message. But re-installed fw with the same version number 00.01.03.00.01 as prerequisite , taken from rigolna.com with build date 2020-03-30, made the significant difference to my approach. I would like to thank all contributors and their effort for making this nice enhancement to my item happen.  8)
« Last Edit: January 13, 2021, 09:50:24 am by nh90wxr »
Offline PT_Dreamer
  • Country: pt
« Reply #1930 on: January 13, 2021, 11:18:31 am »
Hi, just wanted to thank all the work put into this "tune".
I was able to shift some bits to the MSO7024 firmware and got all the "Forevers".
No overshoots, in fact it is shooting just fine as the attached image shows.
I wasn't able to use the patchFinder script (it didn't find the appropriate sections) so I used IDA and the previous posted patches to find the required modifications.
I also changed the bootscreen but had to use mtd3 instead of mtd7 (probably depends on the current shadow image being used).
It is a shame about all the OT though, an "Hide all the BS button" would make things much less painful.
Cheers,
José
Offline luky315
  • Country: at
« Reply #1931 on: January 13, 2021, 11:30:28 am »
That's amazing, could you please share your work?
Offline PT_Dreamer
  • Country: pt
« Reply #1932 on: January 13, 2021, 02:02:36 pm »
What do you want me to share?
I'm attaching the IDA diff for the 00.01.02.00.05 appEntry, you can apply it with idadif.py script.
Offline ineedds
  • Country: kr
« Reply #1933 on: January 15, 2021, 09:16:33 am »
I'm struggling now.
You have same model and F/W with my 5072.
If you could, let me know the hacking procedures you've done and files.
Offline tweini
« Reply #1934 on: January 15, 2021, 10:41:15 pm »
Hi
Your attachment "01_03_00_01.zip" is  according to the chesums for the march firmware and it differs from the file from Omgoleus.
Best Regards
tweini
Offline PT_Dreamer
  • Country: pt
« Reply #1935 on: January 16, 2021, 09:36:58 am »
I'm struggling now.
What exactly are you struggling with?
Offline MoriDove
  • Country: ru
« Reply #1936 on: January 24, 2021, 01:57:06 pm »
Hi, is MSO5074 Hacking the same as MSO5072 ?
« Reply #1937 on: January 24, 2021, 02:54:05 pm »
Yes, they're the exact same scope, the 72 comes with all four physical channels but 2 are disabled in software.
The following users thanked this post: dc8wan, MoriDove
Offline Commodore8888
« Reply #1938 on: January 26, 2021, 03:57:55 pm »
Cheers,
José
The DOOM tradition continues!
Agreed on hacking the 7k series. I did the same with one we have at work for "educational purposes" (but actually this time!) after cracking my own MSO5000 once seeing some work done by mabl. In my case this was right when the NSA had released Ghirdra. Works quite well especially considering it's free. I would think HexRays should be a little worried. I've thought about selling my 5k to get a 7k, if only for the logic head being easier to deal with than the 5k. That said, folks seem to have done a decent job reversing the 5k's logic head into something less silly than the factory offering!
Only beef I ran into is I had to manually make changes to the binary with okteta, as at the time Ghirdra had a bug where it wouldn't correctly apply memory offsets when repacking the binary with your changes. This may be fixed now, been a while since I looked.
Was a lot of fun and a great opportunity to knock rust off my reversing skillset :D I'd recommend trying it to anyone else in here. It's not a super difficult challenge if you know a little assembly and your way around IDA Pro or Ghidra. Mostly just pointer redirection and some changing of JMP instructions.
« Last Edit: January 26, 2021, 04:00:30 pm by Commodore8888 »
Mike D
Offline nichrist
  • Country: gr
« Reply #1939 on: February 04, 2021, 08:34:29 pm »
Hi
I am thinking to upgrade my old LAB Oscilloscope (a Rigol DS1052E bought back in2009) and to buy a DSO5000. The idea is of course to buy a base model and hack for the full power. I am currently between MSO5074 and MSO5072. MSO5074 is 100euro more expensive, is it worth the extra money? Can I hack MSO5072 to 4 channels?
Thank you
Offline Noy
« Reply #1940 on: February 04, 2021, 08:41:02 pm »
Yes you can hack the MSO5072 to 4 channel.
But consider the price of 2 additional 350MHz passive probes.. So 100€ more for 5074 with 4 probes are worth the money. Except you have already 2 additional probes (350MHz)
The following users thanked this post: nichrist
Offline Cnoob
« Reply #1941 on: February 13, 2021, 03:53:43 pm »
Just like to thank every one involved in working out how to hack the mso5000.
I've just hack my mso5104 which arrived yesterday.
« Reply #1942 on: February 18, 2021, 10:11:29 pm »
Went to pop my Dec 2018 MSO5000 open to swap in a little higher volume fan and made a not so nice discovery....
The metal inserts Rigol used to provide threads for their screws, might end up being so friendly to the ABS plastic the scope is made of  :palm: This thing has lived its whole life on a bench too.
The bigger issue is if this starts, you may one day find your scope feet are now stuck.
Still have a year of warranty left, so maybe I can get a new front cover :/1176862-01176866-1
Mike D
Offline Ogawa Mitsuaki
  • Country: jp
« Reply #1943 on: February 19, 2021, 04:11:05 am »
Everyone who is working hard.
I am always grateful for your help.
I also made 70-> 350!
I bought the other options.
The MSO5000 gets very hot.
I installed a 5V fan and filter on the back panel.
5V is taken from the front USB of the MSO5000, but even with the hacked MSO5000, there are no problems so far.
If there is a problem, I will supply it from a USB HUB.
The parts for mounting were created with a 3D printer and attached with double-sided adhesive tape. The probe holder was also created with a 3D printer.
« Last Edit: February 24, 2021, 11:36:52 pm by Ogawa Mitsuaki »
The following users thanked this post: thm_w, crgarcia
Offline jeffjmr
« Reply #1944 on: February 19, 2021, 01:55:45 pm »
Oh that probe holder is just what I need to keep my rat’s nest of probe cables off my bench.
How did you attach it and can I buy one?
Jeff
The following users thanked this post: Ogawa Mitsuaki
  • Country: jp
« Reply #1945 on: February 21, 2021, 02:45:05 am »
Thank you everyone!
I made it as a hobby, so I don't sell it.
I can provide data for 3D printing.
Download the file and print it in 3D.
Since it is divided into 3 parts, please bond the parts with a solvent-based adhesive after printing.
It can be used with only two parts, MSO500_Holder.stl and MSO500_L-ShapedConnection.stl.
Attach it to MSO5000 with double-sided adhesive tape.
Also, this is the place for MSO5000 hacks, so let's end this topic.
If there is a place with such a topic, we will cooperate as much as possible, so please make a place. Or please tell me the location.
Thank you.
*postscript:
I put the modified 3D data on the next page.
There are 3D data for left side installation and 3D data for right side installation dedicated to MSO5000.
There is also general-purpose 3D data.
« Last Edit: September 15, 2022, 11:20:18 pm by Ogawa Mitsuaki »
The following users thanked this post: thm_w, luma, sjm, Protegimus
Online Kean
    • Kean Electronics
« Reply #1946 on: February 21, 2021, 10:35:31 am »
Nice work!  It looks like it should work with many brands of scopes & probes.
There is a thread for 3D printed parts, and although it is mainly for replacement parts, I think this fits in there as well.
https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/
Or you could create a post specifically for your design at https://www.eevblog.com/forum/3d-printing/
  • Country: jp
« Reply #1947 on: February 22, 2021, 11:18:26 am »
I went to the place where I was taught, but it wasn't what I envisioned ...
The parts (L-ShapedConnection) have been redesigned with a general-purpose shape so that they can be used with various oscilloscopes.
However, there are loose corners on the sides of the oscilloscope.
When pasting with double-sided adhesive tape, adjust the thickness before pasting.
If there is no request, this is the end.
Thank you.
Offline TDA7056
« Reply #1948 on: February 28, 2021, 11:33:56 pm »
Thanks folks! I can confirm that procedure described in the post #1901 worked flawlessly for May 2020 build.
Offline Deckardsvr
« Reply #1949 on: March 02, 2021, 05:29:58 pm »
Same here, my MSO5074 is fully unlocked, great job people :-+
Fw : 00.01.03.00.01
Hw : 01.01.000
Boot  : 2018.06.27
Build : 2020-05-18 11:42:06
here's what i did, 3 files on a USB Key :
- 'DS5000Update.GEL' file from post #1298
- 'mayBuildPatch.bspatch' and 'patch.txt' files from post #1901 (inside the archive 01_03_00_01_MayBuild_patch.tar.gz)
On the Scope : Utility, System, Help, Local Upgrade
White screen : Success, reboot, Self Cal and voila, nice and easy !
