Hello folks, I'm about to pull the trigger on a MSO5072, which BTW comes as standard ( limited offer until June the 30th) with almost all the options enabled except if I'm not wrong the ->350 MhZ Bandwidth and the -> 4 ch.
Now, after reading almost all the 70 pages on the thread (pheew!), after thanking all the people who contributed to the task on the subject, I got a few questions.
1) Have no clue on how the MSO5072 will arrive, whether with pre-loaded premium features or not...anyone ? I guess they come in a s/n string to dial in...
2) Given question n. 1, if I'll have a "personalized" license to dial-in, is it worth loading it or should I jump to the hack directly ?
3) After updating to the last official version, I already have prepared the content ( 3 files ) to be copied to the USB drive : 01.03.00.01.bspatch + DS5000Update.GEL + patch.txt with this content :
file_to_patch=/rigol/appEntry
file_to_patch_md5sum=2efa4605b83bf1af48bf6736bfae3255
patch_file=01.03.00.01.bspatch
after_patch_md5sum=965a689e7e5f29c180db4a2aaf21ce6b
the question is : being almost dry of Linux knowledge, and using Windows, wil it sufficient to copy the files on the USB drive or am I forced to use any Linux PC to change any file permission etc etc..?
Thank you, and stay safe !
Ciao
A.
