1.02.00.02 patch
Before: 78d71292a1828ee597a341bd14797e18
After: 86d162a29297ae03af88a6d8f7c40247
Hi I am following this guide:
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg2833308/#msg2833308My MSO 5072 is already patched with the older 01.01.04.04 firmware and I already made a backup containing the memdump and backup folder.
Can someone please confirm if these are the correct steps to update to this:1) Download Update from here
https://int.rigol.com/Public/Uploads/uploadfile/files/ftp/DS/%E8%BD%AF%E5%9B%BA%E4%BB%B6/MSO5000(ARM)Update.rar2) Unrar the files and copy the DS5000Update.GEL to blank usb (fat32)
3) Copy 01.02.00.02.bspatch.txt to usb and remove the .txt extension
4) Edit patch.txt file
file_to_patch=/rigol/appEntry
file_to_patch_md5sum=78d71292a1828ee597a341bd14797e18
patch_file=01.02.00.02.bspatch
after_patch_md5sum=86d162a29297ae03af88a6d8f7c40247
5) Save and copy to usb
6) Files on usb are
- DS5000Update.GEL
- 01.02.00.02.bspatch
- patch.txt
7) Attach the USB Drive back to the Scope, turn it on;
8 ) Wait for the screen shows that USB Drive was attached.
9) Press Utility/System/Help/Local upgrade
10) The screen will turn to white background and follow the instruction to press any keys.
11) After the upgrade process is finished, the scope will reboot.
12) Done! Enjoy!
Just want to confirm this is the correct procedure to minimize the change of bricking.
Thanks
