I just received a brand new 5072 today and come with the fw ver 01.01.04.08.
Those three files from skander36 are perfectly work.
I encountered a problem while using 16GB USB Drive. But it solved after replace with the 32GB USB Drive. It is highly recommend that you have prepared two or more different brand and size USB Drive before perform the upgrade. My failure one is Sandisk 16GB and workable one is Sandisk 32GB (Tiny one).
Case :
When you found that the USB Drive is empty except the GEL file after the backup process:
- Attach the USB drive back to the scope, press Storage/Disk
- If you found there are two or more USB Disk, it means that you may need to try another USB Drive.
Enclosed with all the files from skander36 and backup GEL file from TV84.
My workflow are :
(Please read carefully especially handle the same name GEL files).
1. Format the USB Drive (FAT32 Format);
2. Copy the DS5000Update.GEL.backup.doc to the USB Drive;
3. Rename it by delete the "backup.doc" extension;
4. Attach the USB Drive to scope;
5. Press Utility/System/Help/Local upgrade;
6. After finished the screen will have message told you to reboot the scope;
7. Turn off the scope;
8. Attach the USB drive back to your Mac / PC;
9. Copy all the file except the GEL files and folder back to your Mac / PC for your backup;
10. Format the USB Drive (FAT32 Format);
11. Copy another three files to the USB Drive, rename them by remove the ".doc" extension;
12. Attach the USB Drive back to the Scope, turn it on;
14. Wait for the screen shows that USB Drive was attached.
15. Press Utility/System/Help/Local upgrade
16. The screen will turn to white background and follow the instruction to press any keys.
17. After the upgrade process is finished, the scope will reboot.
18. Done! Enjoy!
Please correct me if any mistake or typo. Thanks!
Thank you so much for all of you to contribute here!
