Backup scripts for Rigol MSO5000 and MSO/DS7000Attached is a .GEL that does a
backup of the /rigol/data directory and the
8 kB FRAM memory. Run as a normal update.
It also does a
memdump (450MB) so you should use a USB disk with size >= 512 MB. (Why this one? Because sometimes its useful...
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
With /rigol/data and FRAM, we can recreate the scope from scratch (as long as the bootloader is OK).
If anyone tests the script, please report the results and how much time it took.
Edit1: Added a .GEL that does a
backup of the full NAND (mt0->mt12).
Since the NAND is 1 GB in size, you must be patient! It could take some minutes.
