Another MSO5074 patched OK (from 01.01.02.03)
Perfect first time, no problem with usb drive using SanDisk 4Go.
Did a backup of my calibration files as suggested, but not sure what to do with them beside a downgrading if needed.
Currently running a selfcal for the first time.
Should I see some diff between calibration files after selfcal?
Here is the steps I did:
ssh local_ip_address using user=root password=root
mkdir /media/sda1/calib_backup
cp -v /rigol/data/* /media/sda1/calib_backup
sync
copy DS5000Update_01.01.04.04.GEL to usb drive (official update)
rename DS5000Update_01.01.04.04.GEL to DS5000Update.GEL
perform a scope local upgrade from the usb drive
scope hard restart
delete DS5000Update.GEL from usb drive
copy DS5000Update_patch_01_01_04_04_usb.GEL to usb drive (patch update)
rename DS5000Update_patch_01_01_04_04_usb.GEL to DS5000Update.GEL
scope hard restart
delete DS5000Update.GEL from usb drive (so you be ready for the next upgrade/patch
![Popcorn :popcorn:](https://www.eevblog.com/forum/Smileys/default/EatingPopcorn.jpg)
Your are done
Thanks for all the hard work doing this patch
