More information on the latest Firmware
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
v00.01.01.04.04 2019/02/20
- Optimized the operating experience of the local upgrade.
- Added the 12-bit high resolution mode.
- Added 500uV/div in vertical scale.
- Added the SCPI command :MEASure:STATistic:ITEM CNT,<item>[,<src>[,<src>]]
to reading the count of measure statistics.
- The waveform can zoom out by drawing a rectangle. If you draw a rectangle
from the top left to the bottom right, the waveform will zoom in. If you
draw it from the bottom right to the top left(the opposite direction),
the waveform will zoom out.
- Added the GND coupling in channel.
- Enriched the color options of the LA channels.
- If the newest version is detected, a red dot will display in the Online
upgrade menu.
- Modified the waveform freeze problem in slow scan mode.
- The boot time is reduced to less than 1 minute.
- Improve the touch experience in the lower half of the touch screen.
- Reduced the noise amplitude of the waveform.
- Modified the problem of decode vanishing after moving signals.
- Modified the error of digital waveform when adjusting the timebase after
stop the sampling.
- The :SYSTEM:SETUP command can successfully save and upload setting
information in remote.
