Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 1118786 times)
bmx and 6 Guests are viewing this topic.
Offline DocSnyder
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #2925 on: August 01, 2024, 08:38:06 pm »
Hello,
i successfully unlocked the MSO5000. Many thanks for your efforts.
But I have a little problem. I am not able to use the Web Control feature. I can see the Webinterface but as soon as i want to use Web control it asks for the login. And guess what: the defaults admin/rigol do not work.
Can you verify that?
I don not know whether this relates to the script but it would be nice to have that feature.
I already tried the older FW and reset to defaults.
Anyone knows whats going on here?
Offline BTO
« Reply #2926 on: August 02, 2024, 01:15:36 am »
Hello,
You're Welcome Enjoy it.
As for Web Control,  Web control has it own little bugs and things and is a bit slower
Don't use Web control
USE VNC VIEWER
So...
- As of Version 1.3.2.2 Rigol has integrated remote support via VNC Viewer  , since you're on 1.3.3.0   you've already got it
- GO HERE
https://www.realvnc.com/en/connect/download/viewer/
Download  REAL VNC VIEWER
Install it
- When it opens there is going to be a white field up the top, ADDRESS BAR
  Enter your scopes I.P. Address in that White Field, Press Enter
  Follow the prompts
- For this to work your scope
1. Has to be connected via Ethernet cable to your Local Area network
2. Your scope must have detected an I.P. Address
3. it's preferable but not necessary that your scope be on DHCP
4. and the I.P. Address range of the scope must be the same range as that of your router
Meaning.......  if you go to cmd.exe and you type in
ipconfig
and your gateway ip  is  10.1.1.1
then your scope ip cannot be 192.168.1.X
it would have to be       10.1.1.X
where X is the Number allocated to your scopes IP Address
if you have issues, Let me know, But VNC is much faster than web control
QUESTION EVERYTHING!!!
Offline DocSnyder
« Reply #2927 on: Yesterday at 10:07:49 am »
Many Thanks for that.
I already tried the VNC feature and it runs well.
But it wouldn't be me if i don't try to find answers to the misbehaviour of the Webinterface Login. Could the script mess up the default Credentials admin / rigol?
Or is that behaviour a bug of the two latest FW versions or came with the browser updates of the last months or years. I can't remember when i tried the Webinterface but i am pretty sure, that it worked as expected.
First step would be that someone who patched the  script tries the Webinterface Webcontrol feature and report whether the login workes or not. And then someone who didn't use the script. All on the latest FW.
This would help me a lot.
Offline BTO
« Reply #2928 on: Yesterday at 02:57:50 pm »
You're Welcome
Glad to hear it
No.. that's fine, i'm not saying you can't troubleshoot it.
I just made the logical conclusion that you want to access your scope remotely and as i know that
VNC is faster in respoinding than webcontrol, i put forward the suggestion that you should use VNC and not worry
about Web Control
NOW.. IF YOU STILL WANT TO TROUBLESHOOT IT, THAT'S FINE We can do that
1. NO as there is no Function in the script that controls that nor did we put in a feature for that.
2. IT'S IRRELEVANT Because... You just need to go into
Utility / IO / LAN
and even if the credentials were messed up, THE SCOPE IS GOING TO SHOW YOU THE USERNAME AND PASSWORD
In saying that,  I have NEVER been able to login to my scope via web control even from the factory.
Another reason why i chalked web control up to being crap
A lot of people have complained about web control
NOW FOR LOGINS
the default is
USERNAME           PASSWORD
admin                       rigol                            i also tried
admin                       rigol(default)                to account for stupidity, Ya know
        Now if the script has anything to do with it the credentials are
rigol                         rigol
root                         rigol
admin                      rigol
root                         Rigol201
admin                      Rigol201
then i did some more research and found that the others having this issue said, THIS WAS THE SOLUTION
In the web interface
go to SECURITY
change the password
FOR ALL , OLD AND NEW PASSWORD  type in    111111     "6  one's"
then hit apply
and you're supposed to be able to login with
BLANK USERNAME
Password    111111
it didn't work for me, but .. give it a go
what else i can fathom is... the computer is blocking it because it's not a secure connection
« Last Edit: Yesterday at 03:00:56 pm by BTO »
Offline BTO
« Reply #2929 on: Yesterday at 04:55:26 pm »
OK, I THINK I HAVE A SOLUTION FOR YOU
Instead of all this mucking around trying to brute force the password,
DO THIS...
Step 1: Use the PYTHON SCRIPT that i've attached,
it's the same one that you used to activate your scope
Step 2: Open Powershell or cmd.exe and type in the following command       (we are going to SSH into the scope to do this)
python Rigol_MSO_LicensingUtility_2.10b.py -e 10.1.1.140Where  -e  is the switch to SSH
Where 10.1.1.140  is my I.P. Address and you should insert your I.P. Address in it's place
Press ENTER
You will see a message at the bottom
Activating SSH...****SSH ACTIVATED****
Now..Open PuTTY.
Step 3. Open PuTTY
if you don't have it download it from here
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
likely iTs the  64bit X86 Installer
when you've done that, Open Putty
Under HOSTNAME/IP ADDRESS  enter your I.P. Address of your scope
Confirm Port number is 22
Connection type SSH  and TELNET
click OPEN at the bottom
Step 4. you will see
login as :
the logins are either
root         (Username)
Rigol201  (Password)
if that doesn't work
rigol
rigol
NOTE : when it asks for the password  THE CURSOR WILL NOT MOVE AND YOU WILL NOT SEE THE LETTERS,
DO NOT HIT BACKSPACE OF DELETE, Just enter the password and hit ENTER
if it works, you will see the diretory
<root@rigol>
Step 5.   Just enter this command
echo "admin:rigol\n" > /rigol/data/user.conf
Press ENTER
Close your browser
Re open it
and in your browser
Type in your scope's I.P. Address
Login with
Username :  admin
Password  :  rigol
WebControl should just open and you should see your scopes screen
LET ME KNOW HOW THAT GOES
NOTE : My scope didn't go into WebControl either (even from the factory)
this got me in and accessing WebControl
As you can see when it works for you, WebControl is much slower
« Last Edit: Yesterday at 04:57:45 pm by BTO »
Offline BTO
« Reply #2930 on: Yesterday at 05:22:20 pm »
Just to address a few things
NO, i'd be very suprised if it did
No, nothing to do with that
i would say it's something with WebControl as many others have experienced this even on past Models like DS2000A and DS1054z
Most get the shits with WebControl and resort to UltraSigma
and i'm willing to be that why VNC Viewer came into support at 1.3.2.2 is because web control was crap and it was probably not worth the developed time
so they just added support for VNC to circumvent the problem.
This is just ...........The Credentials got screwy,  God knows why,   i blame WebControl, But.. Who knows exactly.
At least we can reset it and we know it's not about the activation that we applied nor is is the firmware version
the only quarm i now have with web control is...
I CAN'T LOGOUT
Try it !
Close your browser, do what you like,   you can't seem to actually logout,
it will just log you in as soon as you punch in the I.P. Address and select Web Control
Offline DocSnyder
« Reply #2931 on: Yesterday at 06:06:39 pm »
GREAT!!!
Your last post did the job. First it didn't work. Then i looked into the user.conf file. The password there was including the LF. Then I tried rigol\n as the password and that did it.
So the LF does not need to be pushed into the user.conf.
Many, many thanks. You helped me findig the solution. I needed to make a little last step on my own i wouldn't have found that without your hints.
Dunno whether this is problem of the actual FWs. I will try that tomorrow and reflash the FW.for today.
The following users thanked this post: BTO
Offline BTO
« Reply #2932 on: Yesterday at 06:15:06 pm »
GREAT!!!
No Problem, You're Welcome
and, No, i wouldn't say it's a problem with the F/W
if i were you i wouldn't bother reflashing it,
But, You can if you like
Mine seemed to have the wrong password from factory, so... Yeah
but.. All good now.
Let me know if you need anything further .
Be Cool
