Id be surprised if you got appEntry source. i did this for a samsung tv some time ago, all i got was the linux kernel i could have downloaded from the source webpage. none of their derivative works or things that used the Open Source libraries.
Still, id be happy to be wrong ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
I think I mentioned this before, but 'obviously'. But one can always seem to amaze you
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
Anyway, the request went through, and I got the sources. It was a painful experience. The first time, the archive was corrupted and could not be extracted, so a week went over that. I did get a new download (same archive, but the date inside was 2 days later, so for sure this was a new archive, and it worked. It was a 100 GiB vmware disk image :S Inside there was nothing useful. Just gcc and stuff to actually make the build work I suppose. I never ran the VM, just mounted the disk image and extracted the juicy bits.
So first up, is
U-Boot, the bootloader used. The bootloader is involved when you do the SINGLE key press trick. I'm not convinced it is the correct version, as the fw4uboot.sh update script uses a function called 'showMessage' which I haven't found. Maybe it gets silently ignored? Could someone produce some screenshots with the 'SINGLE' key being in affect and the update messages when doing an update via that way? I recall that when pushing SINGLE, you get a menu to the left of the right key-columns, right?
Anyway, I wrote a wiki page explaining the work and branches, best to refer to that page rather then talking to much about it here:
wiki.
Secondly, the
Linux kernel. I haven't done the work there yet, need a bit more time for that, but have started on it locally
There's a wiki too, but not filled with data yet.
Linux kernel wiki.
Finally, I moved the previous 'firmware dumps' into a new location/name. Those are now
rigol, sorry for breaking any links
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
. The analysis
wiki) still lives there too.
Finally, I've started a new thread, as this one is being abused and really only is about 'help, unlock my rigol' now a days
so focus on software development, Reverse engineering etc, is now moved to here:
Zynq 7000 based rigol software development (Need to get a permalink for that as I probably will change the title :p)
