Dear BTO
I am new to this forum (and a newbie). I am in awe of the work you do. The world would be a much better place if there were more Dave and BTOs in the world.
Your summary of the diverse posts re the methods made it all so clear. Great work. Would these methods work on other Rigol instruments? I have an old Rigol DS1104B. I understand it may have the same board. It has Firmware 012.01.00.04.01.00.01 HW DB53 build 00.59. Is this upgradeable to 200mzh by any of the described methods. I also have a SA - DSA815 TG with Firmware 00.01.19 Boot 00.01.04. Despite searching I could not see any clear method to get either of these units upgraded. BTW I wanted to order (pay for) the DS1104B upgrade and was told by Rigol further licences are not available for that model.
I am also having difficulty locating earlier versions of software. Is there a repository for these?
Cheers dinosaur_rob
Hi mate
firstly
That's ok, no problem
Thanks a a lot i really appreciate that
Dave however is THE LEGEND, Without Dave none of us are here
i have put in my contribution here , but I THINK A FEW OTHER DESERVE CREDIT
As the title states, DRMEFIST0
this is the guy that created the python script (at least finalized the first version)
there were others at the beginning i don't know all their names
and then finally me and SEPPLETRONICS work out the version _3_00 thing of the script to allow the other models to be activated.
so credit goes to SEPPLETRONICS for that one
As for me (and if you're a beginner) this will be good for you,
1. I'm helping people get off the patch method and activated properly and simplifying the process
2. GO TO THIS LINK
https://www.eevblog.com/forum/testgear/post-hacking-rigol-mso5000-post-hacking-tutorial-deep-diveTHERE IS A VIDEO SERIES THAT WILL SHOW YOU HOW TO USE EVERY FEATURE OF YOUR SCOPE.
now as for this
THANKS i appreciate that.
NO, THIS PYTHON SCRIPT IS ONLY SPECIFICALLY FOR MSO5000 scopes
Now, You being a newbie, this is the part where someone would say to you
- See that search bar up the top
- USE IT !!
DON'T WORRY , I'LL HELP YOU OUT
but for the sake of continuity of this post let's not get other scopes mixed up into it as it will confuse future people reading this.
I'm going to PM You with some instructions. but for now just to finish this.
WOW... Not that is old
GOOD NEWS THOUGH, i have been monitoring this hardware hacking thing since Rigol DS1052E , then all the way through the
DS2000A and onwards, at the time your scope came out i had an option DS2000A or DS1052E, I chose the former, Never regretted it.
But lucky for you i do remember this stuff and there are posts on it.
I'll email you with instructions
No, the MSO5000 and the DS1100B have different boards, i'ts not even the same process.
Not by the methods on this post, BUT IT IS UPGRADEABLE... YES
hmm Interesting , A Spectrum Analyzer, I LIke challenges,
Let me look that up for you, Again i'll PM you with this as we don't go into all that on this forum, But again, i will help you so don't worry.
Don't worry, we'll get at least the scope upgraded
EXACTLY, that scope is DISCONTINUED
it's interesting that rigol recommends the MSO5104 as the closest scope, I'd say this is an upsell.
I would say at this time if someone wanted an entry level cheapy, you're better going for the DHO1074, 12BIT SCOPES.
the specs are basically on par with what the DS1052E Was, now this recommendation is a 70MHz option,but again.. Upgradeable
to 200MHz
I'll PM you and explain everything, Let's do everything with PM from here on in or email
