Author Topic: Hacking the Rigol DHO800/900 Scope  (Read 1681823 times)
jscm2000 and 15 Guests are viewing this topic.
Offline scroeffie
Online RogerG
Re: Hacking the Rigol DHO800/900 Scope
« Reply #2826 on: July 17, 2024, 07:40:33 am »
I wouldn't trust a probe in 2kV range, where the ground cable is isolated just with a thin layer of shrink tubing, as seen on the picture in eleshop.
For mains I use a properly isolated Stäubli Isoprobe III with fixed 1:10, which has CAT III 1000 V + CAT IV 600 V rating. They have a separate ground cable with clip, also with its own CAT rating. These probes come in a wide variety, also with higher voltages and 1:100. But this safety has its price:
https://www.staubli.com/de/en/electrical-connectors/products/t-m-products/high-frequency-measurement/touch-protected-passive-probes.html
Offline scroeffie
« Reply #2827 on: July 17, 2024, 10:47:34 am »
« Last Edit: July 17, 2024, 10:49:10 am by scroeffie »
Online RogerG
« Reply #2828 on: July 17, 2024, 11:07:08 am »
For you.
There's always the chance that you get the live wire on the ground cable depending from what you're doing. These shrink tubes are very thin. Another point is that you can have the live wire at the outer case of the bnc then. That's why I use a scope with isolated BNCs for this task.
Offline TomKatt
« Reply #2829 on: July 17, 2024, 11:18:39 am »
For you.
Or a differential probe...  Technically not 'isolated', but exponentially safer than a passive probe with a ground lead.  Especially useful if the device chassis isn't grounded to earth, like much crt gear.
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
Offline scroeffie
« Reply #2830 on: July 17, 2024, 11:23:06 am »
than maybe its best if i buy this one  Stäubli SET Isoprobe III-HP Sonde Aanraakveilig 35 MHz 100:1 3540 V
only thing i dont understand is the 35mhz ?
Offline TomKatt
« Reply #2831 on: July 17, 2024, 11:50:18 am »
That means the probe is only rated for 35MHz - any higher frequencies will be attenuated beyond 3db.  And it's a bit out of my experience, but high voltages are frequency dependent, so that probe may not handle it's rated voltage if that voltage goes beyond 35MHz.
Offline FxDev
  • Country: tr
« Reply #2832 on: July 18, 2024, 07:45:55 pm »
I did as described in this post:
https://www.eevblog.com/forum/testgear/hacking-the-rigol-dho800900-scope/msg5344076/#msg5344076
Second way - generation of additional options
Auto was the option for can trigger and analysis.
Thanks I did it :)
Online RogerG
« Reply #2833 on: July 18, 2024, 08:05:14 pm »
Perfect.
Did BW expansion to 100MHz work, too?
Offline FxDev
  • Country: tr
« Reply #2834 on: July 18, 2024, 09:20:56 pm »
Perfect.
Of course!
The following users thanked this post: RogerG
Offline Lathe26
« Reply #2835 on: July 19, 2024, 04:21:28 pm »
ALL of the serial decoders have a bug where the threshold level isn't multiplied by the probe setting (nb. The attenuation setting, not the physical switch on the probe).
If you don't set the probe to 1x in the vertical menu then you have to multiply your threshold voltage by 10 (the line will be off the top of the screen).
Me? I set it to 1x for serial decoding and the level marker on screen works perfectly.
I thought I was going crazy with this issue a while ago.  Ugh.
Do we know if anyone reported this to Rigol yet?
Offline Aleksandr
  • Country: ru
« Reply #2836 on: July 23, 2024, 09:41:29 am »
Is it possible to build a clock with a battery into an oscilloscope? So that the clock does not go astray.
« Last Edit: July 23, 2024, 09:43:06 am by Aleksandr »
Offline Fungus
« Reply #2837 on: July 23, 2024, 10:08:20 am »
It's much easier to add WiFi and let it get the time over the network.
(which it does automatically)
The following users thanked this post: xduan
Offline Fungus
« Reply #2838 on: July 23, 2024, 10:09:20 am »
They know about it, for sure.
Why they aren't putting out an update is a mystery. It seems like a bug that will affect a lot of people if they don't know the workaround.
Offline mrisco
  • Country: pe
    • Github repo
« Reply #2839 on: July 23, 2024, 03:16:24 pm »
It is better to allow it to get the time from the network, but you need to select the proper time zone. The extended UI shows the date and time automatically if a valid time is retrieved from the internet.
DHO800-900 Extended UI: https://youtu.be/mT4ivaMY7zg
Offline norbert.kiszka
« Reply #2840 on: August 04, 2024, 02:13:33 pm »
Since DSRemote wasn't made to work with DHO800 and DHO900 series, I just ported it by myself.
It wasn't fully tested, but it works :scared: At least with DHO924S and Debian 12.5.
Exporting waveform (to a file) from internal memory doesn't work and I have no idea why. According to DHO800-Series_programmingguide_EN.pdf it should work. Command :WAV:DATA? return is: "The instruction is not supported!". Please let me know, if somebody knows how to do it.
Source code and precompiled binary: https://github.com/norbertkiszka/DSRemote_DHO800_DHO900
Feel free to use at Your own risk  :-BROKE
PS.  I didn't announced Debian and Ubuntu build script yet, so there it is: https://github.com/norbertkiszka/orangerigol
The following users thanked this post: egonotto, RAPo, shapirus
Online RAPo
« Reply #2841 on: August 04, 2024, 03:20:44 pm »
Thanks, did have a quick tryout.
Really pleased; keep up the good work!
Some remarks (running under ubuntu 22.04.3 LTS)
  • user 100 does not have the right permissions straight out of the box. Issue a chmod 0700  /run/user/1000/
  • saving to waveform data does not work
  • sometimes get an error that the bitmap (from save screenshot scope)m has the wrong size.
  • If you invert a channel, the corresponding label is not updated (no down arrow) at the end
Online RogerG
« Reply #2842 on: August 13, 2024, 10:51:41 am »
Nothing new about the DHO :wtf: ?
Online ebastler
« Reply #2843 on: August 13, 2024, 11:01:47 am »
Just bored, or were you waiting for anything specific?  ::)
« Reply #2844 on: August 13, 2024, 11:05:30 am »
If somebody is bored, (s)he can help me with this:
The following users thanked this post: Serg65536, arturmariojr
Offline AndyBig
  • Country: ru
« Reply #2845 on: August 13, 2024, 11:14:18 am »
Help you calculate something on a calculator or help you play solitaire? :)
The following users thanked this post: arturmariojr
« Reply #2846 on: August 13, 2024, 11:24:13 am »
With modifying Linux kernel code, to load Rigol modules from their kernel (they don't care about GPL license - which is very bad). Or eventually with forcing their kernel to work with this (should be easier). With that, it should be possible to run Rigol scope app and use this thing also as a scope.
Edit: also somebody can help with forcing DSRemote with exporting waveform data from this scope models.
« Last Edit: August 13, 2024, 11:27:20 am by norbert.kiszka »
Offline flaotte
« Reply #2847 on: August 13, 2024, 11:27:04 am »
what is the last "goto" version for easy hacking. (Improved tool, not hacking as PoC is the key).
Offline AndyBig
  • Country: ru
« Reply #2848 on: August 13, 2024, 11:40:51 am »
With modifying Linux kernel code, to load Rigol modules from their kernel ...
Why change Android to Debian in the first place? What improvement will this bring to the oscilloscope as a tool on the developer's desktop?
« Reply #2849 on: August 13, 2024, 11:43:02 am »
More useful software on this scope. Which also means easier and faster hacking of a original app.
